250hp/327 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2005, 12:12 PM
E.T. divided by $ spent= Speed
250hp/327 heads
Did the 250Hp 327 come w/ 1.94s???What kinna gross HP do ya think a 250Hp 327 makes w/ an original Torker,750holley vacsec. and a 350HP/327cam(222@050 .447lift)??Through standard 1 5/8 headers.
Thanks
78 monte
Old 01-03-2005, 12:57 PM
Most likely 1.94 valves.
A low compression 327 with headers and those old style heads and cam should make about 325hp if everything is working right.
Slap on a set 190cc AFR heads, Comp Cam 268, Performer RPM intake , and make 375hp.
Later upgrade to a 350 crank and pistons and make some torque too.
