255 pistons in inline 6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2010, 08:56 PM
nyone know where i can find an affordable forged piston set. under 400 bucks? for a 3.68 bore.
Old 06-04-2010, 09:12 PM
Wiki Edits: 31
255 pistons fit the 250 I6 bore and not the 200 I6 bore.. what your looking for is 2.3 HSC OHV pistons.. JE makes forged 200 pistons but there $600 IIRC
Old 06-04-2010, 09:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 200ci and 250ci Ford inline 6 both have 3.68" cylinder bores. The 200 has a 3.13" stroke, while the 250ci engine has a 3.91" stroke.
I see another thread asking about 200 ci rockers- are you building two different Ford inline 6's, is this a typo or are you putting a 200 head on a 250, or what?
EDIT- According to the info the pin heights are same.
Old 06-04-2010, 09:47 PM
Wiki Edits: 31
yes. the deck height on a 250 is just about an inch taller. 10. somthing vs 9. somthing.. the 255 pistons do not fit the 200. I mis-spoke and said bore, but I'v been away from the small 6's for a few years... 250 and 200 heads use the same casting, with the exception of the 1971 High compression 250 head, which was not used on a 200, but swaps out anyway
Old 06-04-2010, 10:17 PM
no but i have run across a 4.6l modular big bore forged piston.
3.7 bore.
.866 pin
1.22 c/d
i CANNOT SEEM TO MAKE THE MATH OUT RIGHT FOR THE 200 INLINE SIX THOUGH. AM AM FUSTRATED
the inline si i have has a
3.68 std bore
4.715 rod length.
3.126 stroke.
now here is all the info i copy pasted from classic inline I hope Mike doesnt get mad i used it.
Sizes and Dimensions
CI
Stroke
Bore
Size
Bore Spacing
Main Diameter
Rod
Diameter
Rod
Length
Centerline to Deck
Piston Pin
Height
144
2.500
3.5
2.2486
2.1236
4.855
170
2.940
3.5
2.2486
2.1236
4.715
200
3.126
3.68
4.08
2.2486
2.1236
4.715
7.808
1.511
250
3.910
3.68
4.08
2.3986
2.1236
5.880
9.469
1.511
221
3.460
3.68
4.08
2.3986
2.1236
5.130
1.511
i cant seem to make the math work out right to find out what rod length i would have to have to make the pistons work. im just eliminating items here so beer with me. With all being said to use the pistons for the 4.6 id have to use a 5.659 rod length. and the question here is where ********* lmao am i gonna find the rod??
Old 06-05-2010, 08:06 PM
hello again i have found my match for some forged pistons.
a subaru wrx Wiseco piston. K588M925 this one is for .020. but for my needs a .040 would work for a slightly honed stock bore on my 3.68 bore.
These pistons .040 measure 3.681
Bore Size: 92.5mm (.020" overbore)
Piston Specifications:
- Stroke: 2.952"(75mm)
- Rod Length: 5.137 (130.50mm)
- Compression Height: 1.286 (32.66mm)
- Head cc's: 48
- Dome Dish: -9
- Gasket Thickness: .054" (1.37mm)
- Deck Clearance: 0.014" (0.35mm)
- Block Height: 7.913: (201mm)
- Compression Ratio: 8.35:1
- Pin Diameter: .9055" (23mm)
i Can use a 221 rod which is 5.13 in length.
only one problem tough. the deck height from crank centerline for these pistons in 1/10 of an inch taller than mine. what could i do here?
Bare with me on this speculation i love to build engines.
identifying pistons?? 2wld4u Engine 12 01-15-2009 11:29 AM
need help with blower pistons malibu68 Engine 3 01-19-2007 11:32 PM
Blower pistons malibu68 Engine 15 12-14-2006 09:49 PM
pistons jerry1 Engine 5 12-14-2006 11:19 AM
pistons that kiss valves bullheimer Engine 16 06-16-2004 02:41 PM
