We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-21-2005, 05:43 PM
Iceberg Iceberg is offline
260 HP or 290 HP GM Crate motor
My '76 El Camino SS needs a new motor. Her 350 (w/ 305 heads) has a dead hole (bad comp rings) & is overpressurizing the crankcase (very messy). She currently has a rebuilt TH350 and a non-posi 2:73 rear end. I have a new exhaust system w/ a new set of Hedman Elite Hedders, "H" pipe, 2 1/2 " pipe w/ Flowmasters. I also have a new Weiand Action+ intake and a new Edelbrock 600 cfm performer carb already on my sick motor. Because of these parts I don't want to switch over to Vortec heads, but I still want the best bang for the buck. Our local Chevy dealer has Goodwrench 260 hp crate motors for $1365 (+ core) and GM Performance 290 hp crate motors for $1745 (no core). The 260 hp motor comes with a 3 yr warranty and the 290 comes with only 1 yr. Is the 290 hp motor worth the extra bucks? My big 2 ton girl sure needs the extra grunt to move her large behind w/ those high gears. Thoughts? I really don't want to throw big bucks into a rig that is my daily driver (sport utility) and not worth the price of an Edelbrock crate motor.
Old 02-21-2005, 06:05 PM
ChevelleSS_LS6's Avatar
ChevelleSS_LS6 ChevelleSS_LS6 is offline
Bitterly Clinging...
ChevelleSS_LS6's barnstar
Wiki editor
Last wiki edit: Cold air intakes
Wiki Edits: 3
I'd get a spec sheet and see the differences fir each engine. See what it would take to get the low-power engine to 325HP or whatever you'd like, and compare with the more powerful, and more expensive, GMPP engine.
If you buy the low-power engine and stick a mild (streetable) cam in it and stuff, you'll probably void the warranty, but you probably will also make more power than the 290HP GMPP version.
If the 260HP has 8.5:1 compresion or something miserable, I'd put thin gaskets on it and try to get 9.0:1 to 9.6:1; anything more and I think you'd need premium (expensive) fuel.
But... I'd swap the gears to something along 3.20s-3.55s for a daily driver. For me, I'd do 3.55s. The 2.73s I doubt are good for much beyond getting groceries and good mileage, and the 3.20s-3.55s would be a good compromise.
Regardless, yours is an Elky rarely seen; most are 70-72 and the 80s styles around here. It's pretty cool, especially since it's a SS. From my understanding, those smog-era SSs was pretty much a stripe/trim package, but it's still cooler than the other ElCamino models.
Old 02-21-2005, 06:20 PM
Ghetto Jet's Avatar
Ghetto Jet Ghetto Jet is offline
pic of my Cobra should be here
Get the 260horse version. The extra $400 is not worth 30 horsepower and two year less warranty. Take that $400 you save and put it towards new gears and a posi unit.
Old 02-21-2005, 06:41 PM
I was thinking the same thing about bang for the buck. It would probably be better to invest in a posi w/ better gears for my 10 bolt than spend close to $400 for only 30 hp. At a later date I also want to run a Weiand 142 blower on her anyway which should give me 50 - 100 more hp (the stock 8.5 compression would work great). Blowers are also only around a grand and would seem to be a better buy.
Old 02-26-2005, 01:26 PM
heavytlc heavytlc is offline
The only difference I can see, going by part#s, is a different cam. The compression is rated at 8to1, on the 290, and 8.5to 1, on the 260. Like I said, looking at the part #'s the only difference is the cams, but there has got to someting more. I would buy the 260, and change the cam. CarCraft had a great series of stories on building one of the 260hp crate engines. With very little work it made 300hp, 400+ with a head swap.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "260 HP or 290 HP GM Crate motor"
To Crate Motor or not to Crate Motor wickster Engine 2 09-15-2004 10:49 AM
GM Crate 350 H.O./ 330 H.P. laitch Engine 4 11-06-2003 09:00 AM
"problems with a crate motor 350/330hp??" ontokid Engine 5 09-19-2003 04:51 AM
Edelbrock or GM crate motor?? HotRodMan Engine 10 01-05-2003 09:56 PM
350 sbc crate motor questions bentwings Engine 7 10-29-2002 08:03 PM
