261 I6 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 02:05 AM
QParker's Avatar
Six Offender
261 Chevy
I am replacing the stock 216 I6 in my 1948 Chevy pickup with a 261~ much like how the hotrodders back in the 50's would do it, so if I put a 4BBL or 3 carb manifold on it(which would be better?), a set of headers, polished and ported the head, raised the compression ratio to around 9.5 or 10 to 1, and upgraded the ignition, what kind of performance could I expect? I figured I could Squeeze at least 1 HP per CI, Right?
Oh, and I was wondering if anyone had any suggestions for a mild street cam and who to get it from? The truck will be a daily driver used for light towing and the occasional race with the guy down the road who thinks his little s10 with a plain 4.3 is all that because it has racing stickers all over it and shiny rims... It's actually geared down for mud boggin'
Old 06-15-2010, 04:57 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by QParker
I am replacing the stock 216 I6 in my 1948 Chevy pickup with a 261~ much like how the hotrodders back in the 50's would do it, so if I put a 4BBL or 3 carb manifold on it(which would be better?), a set of headers, polished and lump ported the head, raised the compression ratio to around 9.5 or 10 to 1, and upgraded the ignition, what kind of performance could I expect?
The inliner will respond to the same treatments that improve its V8 brethren. More carburetor on a free-breathing intake, more cam, more compression, long-tube headers. I like 3 carbs rather than a 4-barrel on an inline 6. Looks more hot roddy and I believe distributes the mixture more evenly to the cylinders. Patrick Dykes is just down the road from me and has most everything you would ever want for the stovebolt. I've been by his store and talked with him. Great guy.
http://www.patricksantiquecars.com/chevyparts.htm
Old 06-15-2010, 05:15 AM
QParker's Avatar
Six Offender
Is there any cam in particular that anyone can recommend to me, like I said before, the truck will be a daily driver used for light towing and the occasional burn out...
Old 06-15-2010, 09:39 AM
Wiki Edits: 326
I've always nurtured an interest in straight 6 motors, so I was just surfing around for parts for you on this 261 motor. I find that this is probably the proverbial red-headed stepchild of the six cylinder family. There isn't much made for it anymore. And what is made for it costs 2 prices.
Have you considered a different six, like maybe a 250 or 292 that would have a better parts availability? Oh, and more power to begin with?
This is just one for-instance. Engle grinds a plethora of cams for the 250/292. See page 12 here.
http://www.englecams.com/downloads/2...le_catalog.pdf
I like the EP-18/20HYD for a good all-around cam with a 4-speed transmission, like a Saginaw with a 2.54:1 first gear and 4.11:1 ring & pinion. You'd need to raise SCR to 9.0:1 to use this cam.
Speedway has some stuff....
http://www.speedwaymotors.com/ProductSummary.aspx?free_text|3/31/2009%2010:52:08%20AM=chevy+six&deptId=0
There's lots of stuff for the later motors. One link leads to another link. Just do some surfing. Take your time.
Old 06-15-2010, 10:30 AM
Wiki Edits: 31
everything external that fits a 235 from '55- on will fit a 261
Old 06-15-2010, 10:40 AM
Not to get off of the original subject, but I didn't think you might know this Tech, but Engle Cams has closed it doors along with Reed Cams shortly after Crane cams folded back in early 2009.
Old 06-15-2010, 03:25 PM
QParker's Avatar
Six Offender
I just wanted to keep the truck looking old, and supe it up like they would in "the good ol' days"
Old 06-15-2010, 06:50 PM
QParker's Avatar
Six Offender
How about if I put 292 rods, cadallac pistons, and offset the crank
Old 06-15-2010, 08:09 PM
You can stroke the 261 using the 292 rods and offset stroking the crank, its been done on the webrodder website. Again, the cylinder head being the biggest restriction, even ported its going to run out of air with more cubes to gain much benefit to impress you.
Old 06-15-2010, 10:12 PM
QParker's Avatar
Six Offender
Does anyone know how much to off set the crank, and how many more cubes this will add?
Old 06-16-2010, 12:29 AM
The stock 261 stroke is 3-15/16", and the difference between the journal sizes is approx .211(261 is 2.311" and the 292 is 2.100"). Also, you have to weld up the crank rod journal checks to use the 292 rods because they are much narrower than the 235/261 rods. Then you will have to add weight to the counterweight side of the crank to balance it, since you have offset the stroke away from it. When your through, you will realize that you have spent more money than it was worth for the few scant HP you might gain. Stick with the GMC swap, or put a blower on the Stovebolt, thats about the only way to increase the HP enough to tell it.
Old 06-16-2010, 01:05 PM
QParker's Avatar
Six Offender
So say I just ditched the stovebolt and went with a 292, did the above stated mods, and put in the solid lifter "EP-22/25" from Engle grinds.
What kind of power could I expect from it then?
Chevy 250 I6 - Turbo? Supercharge? dhunt00c Engine 23 12-26-2013 12:39 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
b or g hemi joe Body - Exterior 5 05-03-2009 02:50 PM
Fitting Chevy 6 lug hubs on my '32 Chevy 29guy Suspension - Brakes - Steering 5 03-20-2009 06:10 PM
old chevy motor to new chevy truck pwchevyman1990 Engine 4 03-02-2009 12:36 AM
