-   -   265DEH in 454? (http://www.hotrodders.com/forum/265deh-454-a-141517.html)
454C10 07-06-2008 10:53 AM
265DEH in 454?
Anyone try a 265DEH in a 454?
265/272 advertised
211/221 at 0.050"
0.476"/0.507"
110 LSA
How is the idle?
vacuum?
low rpm torque?
I'm running a 3.08 gear, 28 inch tire, stock converter, th400, 8.75:1 cr, 781 heads, 454 vortec exhaust manifolds (look much better than logs), and 4400 pounds.
I'm throwing together a 454. I have two cams in the garage. One is a 252H and the other is the 265DEH and I'm having a tough time deciding. The 252H is very mild for a 454 but I do like a smooth idle. My concern is the 265DEH will be a little too much and I think I would rather under-cam than over-cam. Please give opinion or personal experience.
252H
252/252 advertised
206/206 at 0.050
0.460"/0.460"
110 lsa
Thanks.
454C10 07-06-2008 11:53 AM
I just found another choice in my garage. A summit racing cam (sum-1300).
266/276
208/218
0.475"/0.500"
112 lsa.
I think this cam falls between the two cams listed above. I'm thinking I should just use this one.
