267 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2004, 10:56 PM
Erk Erk is offline
I have a nice 267 laying around and i was thinking of getting a roller s10 and putting in that for a daily driver. here's what i was thinking
Stock crank, Stock rods, Stock pistons(i haven't seen any pistons even for a 267), re-ring kit, new bearings,performer rpm intake,stock heads,small cam(.420ish), and an edelbrock 550-600cfm carb, shorty headers. Real low-budget build. Any body ever try this and have any suggestions??
-Eric
Old 05-04-2004, 11:02 PM
poncho62's Avatar
Wiki Edits: 5
If you have the parts laying around, go for it. But, I wouldn't sink much money into it. Nice thing about it is, you can always use the intake etc on a 350 later on when you get one......
Old 05-04-2004, 11:03 PM
DoubleVision's Avatar
I would use a basic performer intake, the 267 needs all the velocity it can get to help low end torque as the factory intake was. I would also use the smallest comp cams high energy grind since it`s suited for small cubic inch engines. If your looking for fuel economy, you picked the right engine, but if your looking for performance I wouldn`t waste my time with it.
Old 05-05-2004, 09:42 PM
Erk Erk is offline
I am looking for economy with a slight umph. I know a 267 ain't gonna do much but it will be slighty "quick".
-Eric
Old 05-05-2004, 10:36 PM
need a boat ancore?
Old 05-06-2004, 09:01 PM
355-5spd's Avatar
The 267 will give you the sound you want, but put your money into a 350 you will be alot better off. and your gas milage will not be much different (depending on what you do to it ) been there done that!
second place sucks!
Old 05-06-2004, 10:08 PM
Erk Erk is offline
Ha i am already building a 357. I could always transfer it over to my 327 i plan to build after i get done building this one.
-Eric
