267 Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2003, 10:02 AM
NAIRB's Avatar
Post 267 Heads
I am considering using a set of 267 heads on my 283, for the sake of having the accesory bolt holes on them. My dad has a whole engine with all of the brackets, starter, flywheel , ect. I thought the little 267 heads might flow about like a stock, 283 head, and yield similar compression ratio. I can buy the entire, fresh 267 for fifty bucks. Otherwise, I'll be stuck trying to hunt down pulleys and old style brackets for the old power-pack heads. What do you guys think? Could I do a little port work on the 267s and get em to run as good as the old power-paks?
Old 01-16-2003, 11:05 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I dont see why not with a good bowl cleanup and gasket match.
Chris
