Thread Tools Search this Thread share on Facebook
  #1
Old 06-27-2002, 08:32 PM
chevellecamino chevellecamino is offline
Post 267 small block chevy
I have a 267 small block chevy from when I bought a 1980 el camino to restore, I took the 267 out, it was a good running motor...I was wanting to know how much work could be done to it to make it a performance motor...I still know the 267 will never be as hot as other small blocks...I was planning on putting it in a 65 chevelle malibu 4-door that was giving to me before I got the el camino...I want to get at least 250 hp out of it...just so I can have some fun in that car when i take it to work insted of driving my el camino...anything is helpful
Register now (free) or login to remove ads
Old 06-28-2002, 04:18 AM
wrenchturner wrenchturner is offline
Post
If Im not mistaken I beleive that motor has a 3.50 bore with 3.48 inch stroke,It would take some doing.I think it only has around 110 hp.just my opinion(wrenchturner)
Old 06-28-2002, 04:24 AM
Tom Tom is offline
Post
A 267 is tiny it has a 305/350(3.48) stroke and pistons the size of thimbles, I think it would be a waste of time and money for this engine.If a small engine is what you want try the 283 or 265(1976/7)these are short stroke motors. 3.0 for 283 and 3.1 for 265, the 265 uses the same diameter pistons as the 305 while the 283 uses a slightly larger bore.283 was the best engine chevrolet ever created,most had forged cranks thick cylinder walls and decent compression , ask some old guys, they were bullet broof,all the perf chevy parts fit also
Old 06-28-2002, 04:41 AM
Post
Amen for the 283,Had one could'nt kill it,major Rs 7000 shift point.(wrenchturner)PS I miss that motor
Old 06-28-2002, 07:11 PM
Tom Tom is offline
Post
hey chevellelcamino got your mail no crates but used yeah they're still out there, I got one. check the boneyards that have older stuff the last 283 was 1967. some reman companies still offer them but never checked,the 307 chevy is a factory stroker useing a 327 crank and a 283 bore(the crank is large journal) I know where there are atleast 10 283s the guy wants 200 apiece
Old 06-28-2002, 07:37 PM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Post
Look in the swap sheets I see 283s allot in the antique/muscle parts sections.Allmost grabbed one myself for $100 needed rings.
Old 10-29-2002, 05:52 PM
stereodud stereodud is offline
Last journal entry: Doors
Talking
To me from what I read That 267 seems to be a great motor. I would kill for one. They were desighned with economy in mind. They have small bore and long stroke wich makes them a great canadate for economy. Most people dont know this but they came with some great heads. The heads are only 1.82 vavle's but they have a fast burn chamber and look almost like fuileis. They also have 58 cc' chambers. If i lived in texas I would trade a 350 for that kicker
Old 01-06-2003, 09:52 PM
HotRod_Malibu HotRod_Malibu is offline
Thumbs up
Finally some one is interested in a 267. I have been teased by every car nut I know when I've mentioned building a mild performance 267. My 2dr malibu is a daily driver so at this point I can't afford to roll around with a 400hp 350. I just want to have an efficient throaty motor with good low end. I have often dreamed of putting a grand national turbo set up on it and put my inginuity to the test. Good luck with your project.
Old 01-07-2003, 03:09 PM
Jay396 Jay396 is offline
Angry
Holy crap dude,
Because of the extremely small bore of the engine in question, it would shrowd the valves of any type of reasonable size. I think that about 210 h.p. could be extracted from the vaunted little motor, I would use the stock heads and do a backyard porting job, and a 3-angle valve-job to bring the flow of the heads up to a reasonable level. I would talk to comp cams to find a reasonable grind that would give you good power and driveability. I probably wouldn't go bigger than a 500cfm carb, or even a Q-jet carb, because it only uses the equivilant air that you engine demands. headers are a must, 1.5" primaries, and a 2.5" collector and you should be good to go.
Old 01-07-2003, 05:06 PM
nicefrog nicefrog is offline
Post
Ok! now we are talking, Here the most common hoon around the street engine is the 253 cu Holden V8, it's a classic engine, it's exactly the same as the 308 cu engine that's won thousand of races all over Australia and even whiped some bmw's in Europe except the 253 has a smaller bore. In the old days people here used to call them plastic motors because the waterpump and the inlet manifold were alloy, at the time Chevs and Fords still had iron parts, they even used to call this motor a boat anchor!. Anyway these days everyone has realised inch for inch it's just as good as a Small Block Chev. The point of the story is, we have and every kid that wanted a gurgly sounding V8 car has owned a 253 V8 in a Holden car. My brothers first car was a good example it was a Torana hatchback with a supra 5 speed, 3.36 L.S.D and a 253 with pocket ported heads, headers a mild cam a "rpm gap" in the stock dual plane manifold a dual exhaust and most importantly a Quadrajet. First time he ever drove that car he tried a Forumla one style spin turn and ripped the 4 link suspension arm off the diff and bent the wheel arch with the now flopping around wheel, it also used to grind the floor pan away at the rear universial joint under power. That car used to spin first gear, second gear and a little slight spin on the change into 3rd, it had a reverse style bonnet scoop and you could clearly see the top of the engine moving side to side under power and braking while you were driving. Best of all it sounded exactly like the Mustang in the movie bullet The whole car weighed 2650 pounds and didn't use much fuel. Well that's my memories of a little V8 and I think that's the kind of car chevellecamino wants
Old 01-07-2003, 05:29 PM
Thumbs up
Those are some impressive numbers. 210hp from a 267 would be nice. I've been told it's a good motor for building low end. The torque numbers would be pretty good as well I would imagine.For a good cam I bought a 264/274 deg duration cam. It's good for low end. Valve float starts at 5000 rpm.
Old 01-07-2003, 08:24 PM
Post
Ok for some more little engine insperation let's see what changes with engine size bore and stroke.
First lets use parts common to all engines and use desktop dyno to see what goes on.
The parts will be pocket ported heads, small tube headers and a Extreme energy 256h cam, Quadrajet and dual plane manifold, and pretty average sized valves of 1.84 inlet and 1.5 exhaust
Chev 262 324 hp@6000 rpm, 324 ft-lbs @4500 rpm
Chev 265 326 hp@6000 rpm, 327 ft-lbs @4500 rpm
Chev 267 320 hp@6000 rpm, 327 ft-lbs @4500 rpm
Chev 283 331 hp@5500 rpm, 343 ft-lbs @4500 rpm
Chev 302 336 hp@5500 rpm, 360 ft-lbs @4500 rpm
Chev 305 330 hp@5500 rpm, 362 ft-lbs @3500 rpm
Chev 307 333 hp@5500 rpm, 364 ft-lbs @3500 rpm
Chev 327 334 hp@5000 rpm, 384 ft-lbs @3500 rpm
Chev 335 330 hp@5000 rpm, 390 ft-lbs @3500 rpm
Chev 350 334 hp@5000 rpm, 406 ft-lbs @3000 rpm
Chev 383 331 hp@4500 rpm, 442 ft-lbs @2500 rpm
Chev 400 331 hp@4500 rpm, 463 ft-lbs @2500 rpm
Ok so you can see that you need heaps more timing on the camshaft to get a bigger engine get moving at anything more than higway revs and also that even with pocket ported heads the heads and valves are the limit not the size of the engine, after 5000 rpm the 302 (probably the best Chev small block) has got all the numbers over the 400 and at 6000 rpm a 302 is making 287 ft-lbs of torque and a 400 has long since spent all his grunt is only making 225 ft-lbs, 400 drivers watch the small engine at the finish line and watch him while your getting wheelspin off the start line too : )
Old 01-07-2003, 10:11 PM
nitro junkie nitro junkie is offline
Post
throw it in the trash can,you can get a used 305 for a few hundred dollers put a performer rpm cam and intake a new timing chain,headers,600 cfm carb
and a performance oriented distributor and coil
and you should be sitting around 230 ish horse power and for a few extra bucks you would be suprised what a 2 inch carb spacer will do I have one on my truck and Im very happy with it
some of this stuff you can get on e-bay for next to nothing like the intake,coil,carb spacer,headers if you dont mind some rust,and the timing chain.
Old 01-08-2003, 08:44 AM
deuce_454's Avatar
deuce_454 deuce_454 is offline
Post
what is wrong with you people.. even if its a small displacement engine you can still tune it and 250 horsepower is not out reach by far. but the engine still displaces 4.3 litres, so if the engine is tuned to the same horsepower pre cubic inch as a 330 Hp 350, you will have the 252 horses you want,
true enough a small block 431 cubic inch donovan all aluminum engine with pro action cylinder heads and kinsler injection will be a more sexy engine and produce moer horsepower. BUT THAT WASNT THE QUESTION..
but i personally think that a goodwrench 350 longblock will be cheaper, it has the horses you want, its brand new, it comes with a 3 year warranty, and the complete engine is 1600 dollars, i severerely doubt that you can rebuild the 267 and tune it to 250 horses for the same amount of money. a 320 horsepower 350 is 2250 dollars and much more the engine to put in a chevelle if you ask me..
in my oppinion the 265 horsepower Goodwrench 350ci. longblock is youe best bet at a good engine in your 65 malibu, and if you want to spend that little extra go with the aluminum headed 320 hp version for the extra 400 bucks.
Old 01-08-2003, 10:08 AM
Post
Im not a big fan of those aluminum heads the only advantage thay have is the wait,and in a malibu
your always going to have the wait problem.
iron heads will produce more horespower than aluminum heads, and if you overheat for what ever reason you dont have to worry about your heads worping.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
