27 ford tudor frame from scratch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2010, 02:20 PM
joeyb's Avatar
hi guy i was wondering if u guys have any good plane for a hot rod or ratrod cause i iam really interested in building one in the near future with my dad so any sugestions or ideas would help thanks ps i want to build a traditional style rod like no mustang front end but like a straight axle u know so thanks.
Old 02-25-2010, 03:20 PM
dinger's Avatar
Check out member Cboy for his journal, you can't go wrong with what he's done.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-25-2010, 03:43 PM
Wiki Edits: 31
Spirit industries has a free set of plans for a T bucket chassis. you can extend the main rails or the length behind the kickup to make it fit what you need.. really simple to build.. good level garage floor, chop saw, 220v welder ( Arc, Mig, Tig whatever you have/ good at using ), 36" clamps, 4-6' level, 1 good tape measure, heavy duty hole saw and 1" drill and the requiered steel materials and you should be good to go.. just don't weld everything solid right away, keep checking it square. add a few cross supports THEN weld it solid, and check square once again... this should enable you to use off the shelf 'T bucket' suspension parts
Old 02-25-2010, 08:30 PM
Wiki Edits: 27
T Build
I've built a few T buckets with 2 X 3 or 2 X 4 .188 wall tubing. chassis depends on how it is to look. highboy? draging the speed bumps ? I bought the CCR plans for the last 2. one running a Jag IRS rear, Youngster on the Tbucketeers site has free plans you can download. Stock 26-7 frames have different front and rear crosmembers. It depends on what suspension you plan on building... look at a few cars to decide what you want.
Old 02-25-2010, 09:18 PM
life is a temporary assignment
this might give you some idea's..New Homemade Ratrod In The Making!!!
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
Ford 9 Inch Posi Swap 31fordcoupe Transmission - Rearend 11 11-06-2009 09:38 AM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 03:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
