27 T Roadster on a 32 Frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2008, 08:49 PM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I think the 27 Ford roadster is the epitome of the term "Hot Rod". They have to be one of the most beautiful of the classic Rods. Having said this, if I were to wrap one of these around my Desoto Hemi, how would I actually go about modifying a 32 frame to mount the body? It's supposedly tough, but I need to know how it's done, preferably in detail, 'cause I've got to start somewhere. I'd LIKE to use 32 frame, suspension, split wishbones, etc, and keep it as mid fifties as possible. NO billet ANYthing on it...
Old 08-29-2008, 10:30 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I don't think I've ever seen this done, but did a search and found this 26 on 32 rails featured on Sanderson's website. It shows the owner's name and city/state. Maybe you could call Sanderson and get his phone number so you could call him and ask the particulars of the swap. Just an idea......
http://www.sandersonheaders.com/readers_ride.php?id=89
Old 08-29-2008, 11:15 PM
Found this one elsewhere on the web.
This is a 27 on 32 Frame with a 289 Ford.
I do not how it was done, but I like it ...
Old 08-29-2008, 11:25 PM
Senior Curmudgeon
Wiki Edits: 326
SWEEEEEEEET
Old 08-30-2008, 05:25 AM
345 desoto's Avatar
THAT'S the look I'm after...and he didn't even need to split the bones...
Old 08-30-2008, 07:06 AM
powerrodsmike's Avatar
Wiki Edits: 161
A while back we had Rod Factory make up a frame for a 27 on 32 rails. IIRC it is narrowed at the rear, recontoured on the sides to fit the perimeter of the body and pinched at the cowl so the frame horns at the front crossmember are not too close together. The rear frame horns are bobbed and you need to fit a new trunk floor to accomodate the kickup. On a 27 the bottom of the body is flat, while the 32 has some upward curve at the front, so some modification to the body is needed, (minor trimming of the bottom of the cowl sides), to make it sit flat. You can see it in the picture that Deuce posted, the frame angles up some starting right ahead of the front of the door.
There is a company making a 32 frame specifically for the 27 that is flat in that area, but I can't remember right now who it is.
I still have the frame, (customer flaked on us), I can take some measurements if you want.
Later, mikey
BE different....ACT normal.
Need Help Setting Up 32 Frame MYWAY General Rodding Tech 4 11-23-2007 12:32 PM
32 Ford frame builder in Central Indiana needed butlerfan Hotrodding Basics 1 11-23-2007 10:49 AM
32 ford frame width at front axle centerline Dirty Steve Hotrodding Basics 4 05-15-2006 07:40 AM
junkyard rearend options for '32 roadster? MattM Transmission - Rearend 7 12-10-2005 11:23 PM
what size motor for a 32 roadster moldmaker Engine 46 12-07-2005 07:31 PM
