273 to 360 motor swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2008, 11:05 AM
I'm putting a 360 into a 65 valiant. my question is what type of oil pan to use and wht kind of headers are avalible for my applications.
Old 01-14-2008, 11:44 AM
Wiki Edits: 49
Check out Schumacher Creative Services. They are Mopar engine swap specialists and should have all the parts and info you need to stick a 340/360 in your Mopar "A" body.
Old 01-14-2008, 12:57 PM
spinn's Avatar
i have to agree with centerline. i think their kit only covers 67+ on up.
the word on the street says...
the lowprofile center sump should be fine. know, the 360 pan is not the same as 273/318/340
74-80' B/A/E body 360 oil pan, the one with no stamping.
there is also a good 93-96? dakota 360 oil pan with a mid-rear sump that ive heard works for the early models.
Old 01-14-2008, 02:34 PM
engineczar's Avatar
that ones tricky in regards to fitting the rear cap on the block, the radius on the pan is different
BSE Racing Engines
Old 01-14-2008, 03:54 PM
Wiki Edits: 49
i have to agree with centerline. i think their kit only covers 67+ on up.......
Actually they do have a kit for the 340/360 swap for 63 and up. According to their web site this particular kit is for: "63-66 A-Body S6 to 273/318 or 340/360 Conversion, 273/318 to 340/360 upgrade, or 273/318 Replacement."
Old 01-15-2008, 12:34 PM
Sweet thanks for the help. What would you suggest I do to beef up the suspension, and frame?
Socal Hotrodders, we need your help s4dustin Hotrodders' Lounge 3 11-06-2007 02:39 PM
318 heads on a 360? Arillious Engine 2 07-14-2007 09:00 PM
360 or a 318 (manual trans in a 65 Dart) sdcovey Engine 2 05-09-2007 08:49 PM
How do I identify a 318, 340, 360 Mopar?? STATUTORY GRAPE Engine 4 04-19-2006 09:15 PM
