274HO6 with stock valvetrain,converter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2010, 03:31 PM
phanline6.6's Avatar
I have an '80 Trans Am with a 355 SBC, TH350, 4.11's, mild cam, not sure what grind, and 993 heads. Very mild build to say the least. Now, I need to pull the intake (think I have leaky gasket), and I'm installing a new gear drive. I thought it would be a good time for a cam swap. I'm leaning towards a 274ho6 grind, was wondering if stock converter is ok, and if stock valve springs are ok. Im not a racer, just a cruiser, and would never be over 5000 rpm. Thanks for any input.
Old 02-11-2010, 03:45 PM
Banned
That cam will work fine wth an otherwise stock engine but it works best with about 9.5 compression and a good exhaust system. If you're running a stock conv. I'd install it an additional 2 degrees advanced. Headers and a free flowing exhaust will make a noticable improvement with this cam.
For springs I woul drun the "z28" springs, you can get them for less than $30 a set. Seem slike chep insurance.
BTW Elgin makes that cam and Summit sells a reboxed cam kit for $130.
I'd rethink the gear drive. A good roller timing chain is adequate.
Just found that cam, and a taiming chain an lifters together in a kit for about $100 from northern auto parts. the cam is E-1785-P
http://catalog.elginind.com/app/Engi...gh+Performance
Competition Products sells the cam and lifter kit for about $100 too,
http://www.competitionproducts.com/E...tinfo/E1785PM/
Old 02-11-2010, 04:03 PM
I was hoping you would see this , cause I've seen you talk about this cam before. I have headers and dual exhaust, and will be getting better heads with stronger springs mid summer. Just wondered if I could run with stock springs until then. Whats involved with changing them with heads on vehicle, is it a big deal? You keep up the good work, you have the best answers on here.
Old 02-11-2010, 05:03 PM
You could if you keep the revs at/under 4000 maybe 4500. If the lifters loft off the lobe, it's kiss the new cam good by. But actually running it for a while more slowly with lighter springs would be a good way to break it in. But you've gotta keep the revs down.
Bogie
Old 02-11-2010, 08:26 PM
Banned
z28 springs are dirt cheap. just get those and save the stress. you can use a piece of nylon rope to help swap them. i can write more on that if you PM me. the Z28 springs are all you need, just forget the gear drive get a good chain set up and use the money you save to get the springs.
Edelbrock Performer vs. Stock Intake crussell85 Engine 8 04-03-2010 09:34 AM
sbc pushrod length using stock rockers GMR Hotrodding Basics 3 07-07-2009 10:17 PM
i want to make more power randy24devan Engine 16 01-02-2009 02:00 AM
Can anyone give me the rates of Stock SB Chevy HP & Torque??? Houman SS '70 Engine 6 08-24-2008 03:32 AM
stock vs. aftermarket intake darom Engine 13 11-03-2004 08:35 PM
