Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 28-3200 Boss Hog Converter
Old 03-28-2010, 02:10 PM
JeffB's Avatar
JeffB JeffB is online now
Pull it PDQ!
I would remove the converter ASAP,I had the same problem when the converter was built the center shaft with the splines was slightly off center when it was welded in,I thought it would be OK to drive a couple days till the weekend and then replace it.MISTAKE!! The front pump went out and the trans was fresh the previous weekend.Get on the phone with Boss Hogg and see if they warranty it and post it here to let us know how you are treated.
