28-48 Spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2006, 06:21 PM
28-48 Spindles
I am building a ground up rat and have a Speeway front end with 28-48 spindles. As I understand it 48-56 F100 backing plates, hubs and drums fit the spindles. Anyone had any experience with this set up and maybe newer or other backing plates and hubs? Found a set of 65 F100 and they apparently are close? Just looking for options if they are out there.
Old 03-29-2006, 06:50 PM
28 to 36 spindles are not the same as 37 to 48
37 to 41 have a round back
42 to 48 have a square back.
42 to 48 are the preferred ones for a 53 to 56 F-100 brake conversion.
The 57 up F-100 backing plates and hubs do NOT work.....but the brake drums will......
I have the 53 to 56 F-100 setup on 48 spindles on my 32 Ford roadster.
Read this magazine article.....
http://www.flatheadv8.org/f1brakes1.htm
As a old Ford guy and a Moderator here.....I want to
WELCOME YOU HERE......
Old 03-30-2006, 12:40 PM
Spindles
Thanks for the tip and the article is excellent. The spindles I have from Speeway are round back but they list them as 28-48 ? anyway I know what will work, thanks again.
Old 03-30-2006, 03:57 PM
The square back ones ( 42 to 48 ) fit the square backs of the 53 to 56 F-100 backing plates without grinding.....on the original 37 to 41 round backs.....some grinding is required. MAYBE the aftermarket Speedway ones will clear without grinding......even on the original round back Fords ........it is not a lot of grinding.
Mustang II dropped spindles vs. std. GS Guy Suspension - Brakes - Steering 4 06-17-2005 11:49 AM
57 Chevy dropped spindles?? bfr57 Suspension - Brakes - Steering 0 06-21-2004 12:05 PM
dropped spindles and granada brakes? flamedfordbronco Suspension - Brakes - Steering 13 02-20-2004 06:06 PM
Modified 1958 Chevy spindles Radical1958 Suspension - Brakes - Steering 0 06-14-2003 10:54 PM
67-72 drop spindles chevyman17 Suspension - Brakes - Steering 2 05-01-2003 05:40 AM
