Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 .125 over
Thread: 283 .125 over
  #25 (permalink)
Old 11-11-2012, 04:37 PM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by ap72 View Post
a stock cast crank is usable past 7,000 rpm, BUT you need to properly machine and build your engine and use the lightest rod/piston assembly you can.
Losing weight on your rotating assembly goes a LONG way when you start going into higher RPM. The same holds true for your valve train.
I have seen plenty of broken cast cranks in 375 horse circle track engines over the years that turn up to 6000 RPM.
