Unless something was dropped on it it should be OK. We used to hang cranks using fan belts, had a hired hand who unbeknownst to us took them all down and laid them on the floor while doing repair on a window. It wasn't caught for several weeks, but the cranks were fine. These were all SJ steel cranks, LJ cranks hadn't come out yet. But checking ANY crank for straightness and cracks should be the normal routine anyway.
Yeah,your bringing back some of those memories.Your right.
Considering the quality of the steel used in the factory forgings isn't the best and that the journals are smaller than a LJ cast crank, it's prolly close to a wash between a forged SJ and cast LJ crank. If you were comparing the same size journals, then the forged crank would be stronger than a cast crank.
If it is a stock forged crank it's only a little better than a good cast crank. The stock forging didn't wear very well. An aftermarket forging is a totally different story. At least that my opinion which is probably worth what you paid for it.
| TH-125 problem | Buick b4 | Transmission - Rearend | 3 | 05-24-2012 08:51 AM |
| turbo 125 trans | anglia427 | Transmission - Rearend | 6 | 04-28-2011 03:37 PM |
| Quick Fuel 30-125 125 GPH Electric Fuel Pump | 64gto71cobra | Engine | 1 | 04-27-2011 11:25 AM |
| 4.125 ??????? | dboyett | Engine | 5 | 10-22-2006 08:44 PM |
| 350 6.125" rods | dirtracerx | Engine | 3 | 09-15-2006 12:09 PM |
