283 .125 over - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2012, 08:41 PM
283 .125 over
Anybody have experience doing this? What years are capable of handling it.
Old 11-10-2012, 09:10 PM
techinspector1's Avatar
Wiki Edits: 326
Only one way to be sure. Sonic check the walls. If they would be minimum 0.135" all around after boring and honing, go for it.
Old 11-10-2012, 09:22 PM
vinniekq2's Avatar
yes,a 301 was popular back in the 60s before GM made them.Its cool to say you made one.
Old 11-11-2012, 12:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
We used to do a lot of these before and right after the 327 came out, the failure rate was less often caused by the wall thickness being too thin after boring than it was by inclusions and sand pockets that ruined the bores.
Your best bet is blocks from 1958-'62, 1959-'62 being preferred because they use the 2-piece rubber rear main seal instead of the rope seal used in 1958.
FWIW there is a 283 block that some sources say was used for both the 283 and the 327. It is c/n 3789817, according to my notes. This is later block (used through '67), so because of that I do not have firsthand info on whether it would be a good candidate or not, or if it's even true in the first place. But it's something you can research if you'd care too.
Good luck.
Old 11-11-2012, 07:36 AM
BOBCRMAN@aol.com's Avatar
Cobalt327 is right. I have bored dozens of 283 blocks to 4".
Air bubbles and slag inclusions are the biggest problem. Usually apearing in the cylinder about mid way down and as life/luck would have it, usually on one of the last cylinders being bored..
The "preferred" blocks are relieved at bottom of the cylinders and look more like a 327 block. Actually a 327 crank fits and counterweights clear. The 817 block was the best. But almost all of these blocks are over 50 years old and I would have them sonic checked, especially between the bores, just for safety.
Back in the day, 301-302 inch were very popular. The TRW forged pistons "escaped" from the Flint engine plant by the hundreds and were cheap on the market.
Old 11-11-2012, 08:22 AM
To go .125 over the block should be sonic tested a short block showed up at my shop a couple of years ago sonic tested it and on cylinder was .088 on the thrust. Was then sold on EBAY by the customer.
I have always gone by Bill Jenkins on cylinder wall thickness which .160
The Following User Says Thank You to CNC BLOCKS NE For This Useful Post:
1Gary (11-11-2012)
Old 11-11-2012, 09:46 AM
so i bought this motor for $25 and was going to scrap everything but the block. is anything worth keeping? how much hp and rpm will the stock crank handle? 375-400hp? 6500 rpm? are the heads worth more than scrap value. not a chevy guy so i'm really lost on quality of stock parts.
Old 11-11-2012, 09:58 AM
vinniekq2's Avatar
283 60 over can easily make 400 hp with stock crank.283 heads dont make any power,give them to a guy that wants an old period correct head. 7,000 rpm is also acceptable
Old 11-11-2012, 10:00 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd hang on to the bottom end if for no other reason than if I tossed it, the next week someone would be around looking for it! lol
But unless you have a storage problem, I'd say to at least keep the crank and rods. Unless the heads are Power Pacs, they probably aren't worth much to anyone. Unhardened exhaust seats and a whole lotta water under the bridge since they were new; at the least they'd need to be inspected before considering using them again.
As far as power to bottom end durability goes, getting too much power out of a 283 for the crank and rods isn't too likely naturally aspirated. I have seen stock 3" stroke bottom ends take 7000 rpm abuse all day ever day w/o issue. I suppose you could build some sort of top end fire breather that could tax it, but anything driven on the street isn't gonna hurt it.
Thread on the PP heads and some estimates on power: Powerpack Heads
Old 11-11-2012, 10:22 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
This a small journal 283??. I think they where back then.I forget the yr change on that. Back in the day we used to destroke a 327 with 283 cranks.We had one that we ran D/MP that with as Isky solid roller,TRW forged pistons,M/T aluminum rods and Mondello double hump ported heads,we buzzed to the moon.If you wanted to destroke a 327 someday,it might be worth keeping the bottom end.
Some of the nostalgia drag guys might want that.
Old 11-11-2012, 10:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There was never a factory 283 that was anything but SJ crank/rods.
Old 11-11-2012, 10:35 AM
vinniekq2's Avatar
1968 the 327 was either small journal steel or large journal cast.
Old 11-11-2012, 10:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It sure was. That was the year things changed over. Like the LWP front accessory dress for cars.
Old 11-11-2012, 10:42 AM
the guy i got it from had the crankshaft laying on its side for sometime, can i check the warp with a dial indicator and the crank laying in block.
Old 11-11-2012, 10:57 AM
vinniekq2's Avatar
I dont see why not? crank straightening used to be an art
TH-125 problem Buick b4 Transmission - Rearend 3 05-24-2012 08:51 AM
turbo 125 trans anglia427 Transmission - Rearend 6 04-28-2011 03:37 PM
Quick Fuel 30-125 125 GPH Electric Fuel Pump 64gto71cobra Engine 1 04-27-2011 11:25 AM
4.125 ??????? dboyett Engine 5 10-22-2006 08:44 PM
350 6.125" rods dirtracerx Engine 3 09-15-2006 12:09 PM
