Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 with 305 heads
  #21 (permalink)
Old 08-11-2012, 12:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by alsadler View Post
That is the way it was origionally but it did not want to even idle. Had to drive with two feet. We did set it to six and 12 and it did start but only once then it stalled and we could not get it started. does not seem to be timed right eather way, but tommorrow is another day.
Another very common mistake is the plug wires for #5 and #7 to be swapped. The firing order has #5 and #7 right next to each other on the distributor cap- AND the spark plugs are next to each other at the cylinder head. This gives two chances to transpose the wires. The engine will run like that, but poorly.
