Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 with 305 heads
  #24 (permalink)
Old 08-11-2012, 06:49 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
What cam is in this motor. Did you verify true TDC on the balancer using a piston stop and correct the timing tab yet?
get a timing light. Install a engine ground wire to the firewall.
