283/327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2002, 10:03 PM
New Member
Post 283/327
I have 283 and want to put a 327 crank in it and bore it to a 4 inch bore. I cannot determine whether I have a thick wall block and whether the block has adequate crank counterweight clearance needed for the 327 crank as there where 2 different types of 283 blocks. Does anyone know how to tell the difference between the blocks with clearance and the ones without? I am unsure of the block's year but I have the numbers;
3849852
SC11 ADN
Old 12-07-2002, 10:58 PM
Post
look at the bottom of the cylinders the bottom of the cylinder walls will be dished not flat.and you need the small diameter crank also.earlyer 327 blocks(wrenchturner)hope this helps p.s.I think that number may be 1962
[ December 08, 2002: Message edited by: wrenchturner ]</p>
Old 12-07-2002, 10:59 PM
New Member
Post
The crank should not be a problem , but you should sonic check your block for the bore size , any good builder should be able to do it or get it done for you
