283/327 Low Budget Build?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 11:13 PM
Anyone Know? Can I Put A '67 283 Crank And Rods In A '68 327 Block With 327 Pistons? Id Like To Use The Larger Bore With The Shorter Stroke To Make An Over Bored 302. I Know The 283 Is A Small Journal But Im Not Sure About The 327 Block I Think It Is But Im Not Sure Of When They Went To The 2.45 Mains From 2.3 Or If Anyone Sells A Spacer Bearing To Make This Work In Any Large Journal 4" Bore Block. Thanks In Advance
Old 09-03-2006, 07:29 AM
Will I ever get it done?
Last journal entry: Hood
IIRC, 68 was the year you could get small or medium journal 327's, depending on when they were built. If you have a small journal crank and a medium journal block, you will need to go to:
http://www.childs-albert.com/catalog/
Click on the bearings hyper and when the pdf file opens, go to the second page and find this part number: MBS-327-350
Since the 283 stroke is 3" and the 327 stroke is 3.25", the pistons will come up 1/8" short of the deck. This won't give you much compression. You need 302 pistons. There are several choices. Here is one for a 0.030" overbore.
http://store.summitracing.com/partde...ew=1&N=700+150
At this point, I think it is clear this is no longer low budget. What's wrong with the 327 crank. The only substitution for cubic inches is rectangular dollars.
Old 09-03-2006, 09:43 AM
runn141's Avatar
on 283 blocks with casting number 3970020 can be bore from 3 7/8 to 4 inch i know for sure. then my cousin said all 283s
could but i would ask a machine shop first
Old 09-03-2006, 09:10 PM
the 327 is block only already machined i bought for $25 but its .080 over the ## is 3914678. any one have a site or a list of over bore limitations by casting numbers? i found pistons and rings for $89 i thought i could throw something together for little dough but it looks like a money pit now, the 283 is still running in my 67 c10 i figured i could get more ponies with a bigger bore, ill have to check the 283 ##s and go talk to a machinist about over over boring it, i just like the idea of a high fast revving 3" stroke with less dead zone then a 350 3.48 stroke i have several 350s just thought it might be fun to see if i could make some no money power with extra parts.
Old 09-03-2006, 09:23 PM
runn141's Avatar
if the 327 is truly over bored 80, you got screwed! but i know a machinest that builds race engines and he said #3970020 blocks can be bored to 4 inch and on to 60 over. but im not sure about the other numbers if they can, all 307s can be bored to 327s because 307, 283 are the same block. 1 might say a number for a 283 and really be 307 only way to find out is pull the head and measure the stroke. and as far as .080 over ive never heard of that. grenade motor
Old 09-10-2006, 01:27 AM
im guessing since companies manufacture pistons for an .080 over 327 that its not impossible!. yet its a little thin walled for me. i have a friend who races dirt track and right now hes running a 350 .120 over. and his quote when i asked about his over bore. "theyre grenades, sooner or later theyre going to blow" and for being screwed im sure i could sell it on ebay for the whopping $25 i paid for it. or even make my money back on the main caps. im not going to use it i already have 4, 350 standard bore engines laying around i just wanted to play with a 3.0 stroke crank out of my 283 but its too much trouble ($) for a grenade once i have to buy pistons.
Old 09-10-2006, 02:21 AM
runn141's Avatar
i dont know that they do manufacture pistons that much oversize
Old 09-11-2006, 09:21 AM
What is dead zone in a 3.48 inch stroke?
You don't think a 350 is a high fast reving engine? Maybe you aren't using the right cam or valve springs or cylinder heads.
My 350 revs up very quickly to over 7000 rpm with only a compcam 292H cam. And I even had the crank stroked 0.070" more for a few more cids.
With stock heads and a small cam a 327 will rev better than a 350 because it requires less air than a 350. A 350 needs more head and more cam than a 327 and the only reason it sometimes doesn't seem to "rev" as well is because it is being choked by poor flowing cylinder heads and a small cam.
If you what more power junk the 283's and 327's and build a 350 with a good set of heads and a long duration cam.
Old 09-11-2006, 09:36 AM
A 283 is a small journal motor and the 307 is a medium journal motor. They do share a common bore size, but they do not share a common block. The 3970020 blocks are 307 blocks, and I would not bore one more than .060". If you feel the need to go to a 4" bore, just use a stock 350 block. Some older 283 blocks can be bored to 4" because they have thicker walls.
Old 09-11-2006, 10:18 AM
runn141's Avatar
should be same journal size. they swapped cranks in 283 &327 to begin with. casting #3970020 is also 283 ive torn one down measured the stroke. and its more conveniant way to make 302 or 327, little bit harder from a 350 where journals are bigger.
Old 09-11-2006, 11:41 AM
They're not the same journal size. The 68-up 307 castings have a medium journal. If you want to make a small journal 307, use a 327 crank in a 283 block. If there was a large journal 283 made, you'd see the cranks being hoarded.
Old 09-11-2006, 11:53 AM
runn141's Avatar
i never said 283 had a medium or large journal
Old 09-11-2006, 12:03 PM
runn141's Avatar
i apologize to everyone on this thread i was wrong.the block i tore down was an 810# block that listed as 307 and was 283 . anovakind67 is right # 3970020 is a 307 and i remember now it was a 307 that my cousin had that could be bored to a 327. now i did hear all 283's could be bored to 4 inch but im not sure now..........sorry my bad
Budget Beater Build Nightfire Hotrodders' Lounge 15 04-15-2006 02:39 AM
Build a kit car Dutchman General Rodding Tech 9 09-23-2005 05:39 PM
First Rod Build - T Bucket , here we go Gr8lite Hotrodding Basics 10 06-29-2005 03:42 PM
383 Build Questions Mustangsaly Engine 3 06-14-2005 10:53 AM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 08:52 AM
