283 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 05:57 PM
65 c10, 283 tbi, 700r4, pb, ps
howdy to all
i've got a 283 im rebuilding and was wordering gas mpg i git?
it's a 1965 c10 3 on the tree with a 3.73 rear. Stock 2 barrel
cool site
Old 02-18-2005, 06:01 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Exactly how are you rebuilding it? What vehicle? What usage?
Stock in a light vehicle and your mpg shouldn't be too bad...injected on alcohol in a tank and it will suck.
Old 02-18-2005, 06:40 PM
lluciano77's Avatar
The 283 will be a little underpowered. I think you would get better mileage with a bigger cubed SBC.
My guess on mileage would be 15 mpgs or less. But who knows?
Old 02-18-2005, 07:55 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Believe me the 283 is a fine motor for those trucks.True a 350 would pull more but my 1/2 ton 69 C-10 had the 283 in it with the three speed and it was fine. Bullit proff engine UNLESS you deliberatley neglect to put oil in one. Make sure the grommets are in good shape on the linkage. They are a often overlooked piece that will cause the linkage to bind up. Expierence in that area.
Old 02-18-2005, 08:20 PM
i don't think i have grommet do ya have a pic and 350s are like buts! everyones got one
Old 02-18-2005, 08:27 PM
OddRodder's Avatar
CORNFED and INBRED !?!
That's FUN-NY! and true too! Tuned and tweaked, that lil' 283 might get close to 18mpg, but the 3.73's will hurt highway mileage.
Old 02-19-2005, 09:18 AM
so what it just a lot cooler that a 350
Old 02-19-2005, 11:34 AM
lluciano77's Avatar
The Chevy 350 seems to be the perfect balance between power and mileage. They are very efficient that way. When you underpower a vehicle it can actually start to waste mileage. Same thing with adding too much power. I think the 283 will get worse mileage than a 350. Especially if it were a roller cammed late model 350 with Vortec heads.
Old 02-19-2005, 12:09 PM
so what 350s are still like buts!!!
Old 02-19-2005, 12:20 PM
lluciano77's Avatar
What?
Old 02-19-2005, 12:22 PM
RCastle's Avatar
You should have grommets! They are a Nylon push in insert that is hollowed out to accept the enmds of the different rods that controll the shift. There is supposed to be one on the first rod coming off the steering shaft housing under the hood. That rod should connect to another one,running from a bracket off the frame on the left side. With these grommets missing they will eventually begin to bind,causing you to get out of the c ar in the heavy rain and lay down,getting completly soaked(Still Bitter After All These Years). Believe me the 283 is fine for that. The 350 would not be bad,but if you are looking at just saving a buck and fixing what you have,it is fine. Take it from expierence on that engine. Alot of people knock the 283 just because it is not a 350,I was the same way when I got the truck.But after driving it for a summer,I found out it was great.It was just all the other bugs with that old truck that put me over the edge.
Old 02-19-2005, 02:57 PM
no i do not think i have any
Old 02-19-2005, 04:12 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
350s are good engines, but, see above.
Old 02-19-2005, 04:22 PM
my dad has a 350 it's a sweet engine but 283 sounds way er
Old 02-19-2005, 04:29 PM
lluciano77's Avatar
My Briggs and Stratton lawn mower sounds pretty cool, but I didn't consider it in my choice of new engines for the Camaro.
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
283 stroker (307 cid) question Viking427 Engine 4 04-04-2005 10:40 PM
283 piston alternitave jeff of nc Engine 3 10-10-2003 04:33 PM
high performance 283 steve Engine 2 06-22-2003 03:25 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 12:48 PM
