#1
283 advice
ok i am playing with an idea and would like some input.
taking a 283 block 327 crank and 302 rods. now i would like to see around 500 hp with high rpm on this with no bottle or charger. ideas? Register now (free) or login to remove ads |
#2
Welcome to HRBB
Really? how about this for an idea,,, Big Block Chevy Your 283 order is too tall for this cat,,,it can be done but I hope you have extremely deep pockets
#3
hahahahahahaha |
#7
hahahahahahaha |
#8
We've gotten so many of this exact same question over the years but it still brings laughs. Think in these terms: More cubic inches make more power, its easier to reach 500 horses with a 350 than a 302 because it's 50 cubic inches bigger. And yes, while a 327 block and a 283 crank makes a 302, there are no "302" rods, as all the generation 1 small blocks used the same 5.7 inch rod except the 400 which used 5.565 rods. You want a 500 horse 302? You'll need about $6000 at a minimum and it won't be street driveable.
#9
hahahahahahaha |
#11
Ah well building almost any small block isn't really difficult until you start stuffing 4 inch stroke cranks in'em then it gets a little complicated.
If you want to build a high revver by all means go for it. They sound great really revved up there, no arguements there. |
#12
and actually there are 302 rods the camaro ran a 302 in the late 60's large journal and small i have already found that the rods i need are from a 66 camaro 302. now do i bore the block .125 to run 205 160's and domed pistons for higher compression or stick with the largest valves i can run in the smaller cylinder. and just so you know i am not joking i will have this done and rolling by spring
#14
Let us know when you find those 66 Camaro rods........
| Thread Tools | Search this Thread |
| Similar Threads for: "283 advice" | ||||
| Need advice on 468 bbc | quicksilver67 | Hotrodding Basics | 5 | 03-08-2011 06:37 PM |
| need advice | jjpodlas | Hotrodding Basics | 2 | 03-06-2011 05:13 PM |
| kid needs advice 400 sbc | 76ChevyNova | Engine | 9 | 07-19-2006 12:37 AM |
| I need some cam advice | StevenC | Engine | 10 | 06-15-2005 08:20 PM |
| Need some advice!! | Angel1emt | General Rodding Tech | 4 | 09-10-2003 06:46 PM |
