283 Assembly - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-11-2012, 10:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Mertz View Post
The problem I am having is that the crank gear does not have a dot so I am assuming the correct position to have it set is with #1 at TDC and then align the dot on the cam gear so it is at 6.
Gotta be a dot somewhere, I would think. You've looked at both sides, it's not on backwards?
Otherwise I have to say you need another crank gear w/the index marked on it. W/o the mark the chances of installing the cam out of phase is just too great IMHO.
  #17 (permalink)
Old 11-11-2012, 11:11 AM
283 Assembly
You have three key slots on the crank gear. Usually the the key on the left has a square retards the timing. The key on the right with triangle advances the timing. The center key with the dot is straight up 0 degree advance. If the gear is not marked I would take it back and get another one that has the markings. If you installed it with the center key, when you install the timing cover and the balancer the line on the balancer should be on 0 on the scale.
  #18 (permalink)
Old 11-11-2012, 11:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You might want to look at it under good lighting and magnification to be sure the mark isn't just very light.
  #19 (permalink)
Old 11-11-2012, 03:43 PM
Mertz's Avatar
What an idiot I turned out to be!!!!!! Installed the gear just like it showed on the instructions with the square side to the left because I could not find a dot on either side. I went online to look for better instructions and found out there is not supposed to be a dot. If you use the square key way you look for a square mark, the round keyway a round mark and the triangle keyway a triangle mark. As it turns out I did have the gear on backwards. I took my magnifying glass and found the triangle mark on the back of the gear. After some persuasion I got the gear off and flipped it over. I got the O mark aligned with the dot on the cam gear. As it turns out the #1 piston is in the same spot as it was when I had the gear backwards. I feel a lot better about the alignment now.
Thanks for putting up with me on this.
  #20 (permalink)
Old 11-11-2012, 03:46 PM
techinspector1's Avatar
Wiki Edits: 326
Everyone on this board has "been there, done that". None of us were born knowing this stuff.
  #21 (permalink)
Old 11-11-2012, 06:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No truer words have been spoken on this thread. Don't sweat it even for a minute, Mertz. Chalk it up as a lesson learned and move on. Before you're done you'll be an expert on all this.
  #22 (permalink)
Old 11-11-2012, 08:29 PM
Mertz's Avatar
Thanks guys. It is a lot of fun to learn about all this stuff. I once owned a restored 67 Malibu SS and although it was one of my dream cars it wasn't that much fun because there was nothing for me to do and figure out how to fix.
I worked in a "service station" in high school where we actually did some mechanical work and it was what i really liked over pumping gas for people that came in and wanted "2 buckets worth". Gas was 25 cents and that would give you about a half a tank, enough to go crusin for the night and then some.
I sometimes tell my wife that I am disappointed because I haven't turned a wrench for 6 months. Fly fishing does fill that hole partially but not completely.
This is a great website. I can see how many more people are signing in since I started. Sometime over 1000 people looking. Thanks to all the people who organized the site and keep it running. There is a lot of knowledge here that can be shared by a lot of enthusiast.
Re-assembly order? BMM Body - Exterior 11 08-25-2008 10:35 PM
head assembly Q, more like dis-assembly bullheimer Engine 5 11-27-2007 04:48 AM
283 crankshaft into 283 south65ss Engine 1 05-08-2007 08:25 PM
AN- fitting assembly GCD1962 Hotrodding Basics 4 12-26-2005 05:51 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 12:48 PM
