283 balancer on a 400 sbc?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2006, 08:32 PM
Half Breed's Avatar
Even my lawn mower is fast
Anyone ever use a 283 balancer on a 350 or 400 sbc? I figure it would reduce the reciprocating mass quite a bit.
Old 02-22-2006, 08:37 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
It will work on a 350 as they are internally balanced. But it won't work on a 400 as the balancer helps to balance the crank (external balance)
Old 02-22-2006, 09:23 PM
Half Breed's Avatar
OK, so if it was done on a 350 would this help performance??
Old 02-23-2006, 08:33 PM
Somewhere I saw a test where a larger balancer caused the valve & ignition timing to be more accurate, and it had better power.
427 sbc out of a 400 camaro409 Engine 23 08-02-2009 09:25 AM
sbc 400 81camprj Introduce Yourself 4 02-15-2007 10:25 AM
400 SBC oil leak gearhead77 Engine 4 08-25-2004 09:15 AM
SBC 400 shim head gasket sb72elcamino350 Engine 4 06-28-2004 07:47 AM
My sbc 400 build up, please review Guitar Charlie Engine 13 06-17-2004 08:06 AM
