Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 Big Problem
Thread: 283 Big Problem
Old 02-23-2009, 12:26 AM
Studebaker Studebaker is offline
You stuck a valve, plain and simple. you have probably bent the valve and that is why it is stuck. Take the head off, replace the valve and guide and check to make sure the piston is not damaged. Yes it is a lot of work.
