02-24-2009, 08:26 PM
Quote: Originally Posted by ericnova72 Should fit the 355 just fine, but it always depends on cam size and the size of the valve relief in the piston. ALWAYS CHECK IT! Pistons will be fine, but if the cam is a flat tappet hydraulic, you run a risk of flattening a lobe by only running it for a short time. You've got to fire it up, immediately get the rpm's above 2200 (IMMEDIATELY!!!, and 2500-3000 is better) and run it for at least 20 minutes like this to get the cam and lifters broken in. You can't just fire it up "to see what it sounds like" for a minute or two. Hopefully you already know that.  |
yea pops is pretty good about that, i believe he is running a 264 555 cam, but his is solid lift,, i should have got a solid lift,, i am thinking of swapping my cam out for something a little smaller and making it solid. what cam would you suggest, i want it to sound eratic still ( your instruction above are your suggestions for my cam right)
Register now (free) or login to remove ads
