Thread Tools Search this Thread share on Facebook
  #1
Old 03-06-2006, 11:49 PM
Super Chevy's Avatar
Super Chevy Super Chevy is offline
BRB carring
283 Block damage, PICS.
What do you think, garbage?
Register now (free) or login to remove ads
Old 03-07-2006, 12:12 AM
BuckSatan BuckSatan is offline
New Member
283? If its not in some $100,000 restored car I'd say junk it. Hell, if you lived near me, Id give you a perfectly good 350 to replace it.
Old 03-07-2006, 12:16 AM
BRB carring
lol! well geeze, i wish i lived near you!
Old 03-07-2006, 12:24 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
I got a 350 block under the house that looks worse than that, when I got it 2 rods had came unglued, I had it magnafluxed and ran it for 2 solid years, still nothing wrong with it. As long as the piece missing at the bottom isn`t in the rings and there`s no cracks there`s nothing wrong with that block.
Old 03-07-2006, 12:43 AM
scholman scholman is offline
Super Chevy,
I think I would put a sleeve in the one cylinder for sure and the one accross from it too. The chips on the pan rail are nothing but I would grind the sharp edges to stop cracks from forming.
Scholman
Old 03-07-2006, 01:10 AM
New Member
Why would you try to save a 283? They give them away. Like a 307 or 305, the junkyards are littered with them.
Old 03-07-2006, 12:57 PM
1982 SS's Avatar
1982 SS 1982 SS is offline
Flamethrower
Last journal entry: More Cooling fan pictures.
I would just set that block aside if I ever needed it for a perfect resto and find something a little bigger than a 283.
Or you could clean it up real good and make a coffee table out of it. Bolt a piece of glass or Lexan to mainbearings so you car see the carnage. Make it a conversation piece.
Old 03-07-2006, 02:38 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
I've got a 327 block with a chunk out of the bottom similar to that. The block was checked and it had no other cracks/damage. I'm just going to leave it. If you sleeve, you'll have to bore all cylinders because it distorts to adjacent holes.
Old 03-08-2006, 08:04 PM
BRB carring
i think its just going on the shelf for now, the local machine shop said they would inspect it for around $70 or they have 283 shortblocks there already inspected and good for $75.
Old 03-08-2006, 09:56 PM
Blazin72's Avatar
Blazin72 Blazin72 is online now
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I've got a 350 with a chunk like that missing from the bottom of the #5 cylinder, been together for 7 years and about 35,000 miles like that. As long as it's checked for cracks, deburred and out of the ring travel area it should be ok.
If the crank is good you could always find a 350 block and make yourself a 302... (Do they make spacer bearings for med. journal blocks to small journal cranks?)
Old 03-08-2006, 10:00 PM
BRB carring
ive considered doing a 302, actually its on the wish list but i can't afford the pistons at the moment. i dunno if i trust bearing spacers.
Old 03-08-2006, 10:22 PM
TechnTool's Avatar
TechnTool TechnTool is offline
OldSchool MotorHead
Sure it's still good, for the following uses:
Boat anchor (degrease first)
Door stop (Big door)
Extra weight for pickup truck in snow
Have at it, But for running? C'mon man, in my 24 years of engine building I would not put that back together.
Old 03-08-2006, 10:43 PM
Blazin72's Avatar
Wiki Edits: 19
If it isnt cracked or anything how would that make the block non-functional? If it's out of the way and the rings wont hang up on it whats the problem with it? Just make sure it's deburred so it doesnt develop a stress fracture... I have had zero problems with the 350 I have with a similar sized chunk missing.
I'd be more worried about the oil pan rail not sealing well because half of the sealing surface is missing.
Old 03-11-2006, 12:51 PM
TechnTool's Avatar
OldSchool MotorHead
The problem with this block, in my opinion, is the fact that the structural integrity is comprimised. As the block heats up and expands, there will be uneven expansion causing stress. When ever there is a part that is stressed, you have a potential for failure. Why waste the time and money with a questionable block, when there are so many good blocks available? If this block passes a flux test and has no cracks, then it means that you can start it up. BUT, it does not mean that you can run it. Take the advice as sauce for the goose, and make your own decision as for where to spend your money and time. Good luck
Old 03-11-2006, 05:58 PM
coldknock's Avatar
coldknock coldknock is offline
It looks like it's been running like that for quite a while. The surfaces, where the missing chunks were, are not fresh.
Rings bearings and a hone job should perk it right up.
Larry
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "283 Block damage, PICS."
ThreadThread StarterForumRepliesLast Post
WRX Pics, See What $7,000 in damage looks like.Ghetto JetHotrodders' Lounge1010-22-2004 10:30 PM
Small Block Vs. Big Blockbfrett123Engine310-14-2004 05:27 PM
SBC Block I.D. Casting# confusion1Fast65ElkyEngine210-13-2004 07:44 PM
picture's of big block s10my454s10Engine609-17-2003 06:57 AM
350 block pre-purchase checklistidrva55Engine401-05-2003 10:52 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
