283 cam choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2008, 08:48 PM
283 cam choice
Im bolting together a 283 and Ive got quick camshaft question.
The motor will see action in a '79 Buick Regal. No street, no strip, just backwoods, unsanctioned dirt track racing. Safe? Not really. Fun? You bet!
My question is this.. will I pull the studs out of the heads running a short lift, loooooong duration cam? The cam Ive got in mind is an Isky grind, part #201LR4. .420 lift / 296 adv. duration / 248 duration @ .050.
There really isn't a good reason at all to run such a large cam. Performance doesnt matter much because of the 'bald tire' rule. Good tires arent allowed, mostly to keep the ragged out cars from achieving a highly dangerous speed. Id like to run such a cam because Im not old enough to have experienced the glory days of small cube sbc's wound to the moon and Id just plain like to operate one myself. Heck Ive never even heard a small block spin past 6500r's.
Will the press fit studs stay in the heads? Will I be able to break that cam in without flattening it? Will the valve springs keep the valves away from the pistons? Any advice is appreciated.
Old 01-06-2008, 10:18 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi John,
Sounds like fun,
283 + .060=292
Vortec heads w/1.94/1.500 valves from GM Performance
pn. 12559060
Speed Pro domed forged pistons#L2275F
for about 101/2.1 CR
Edelbrock Super Victor intake for the Vortec's pn. 2913
Should spin well past 8,000
Also you can have the block sonic tested to see if you
can bore it .125 over making it a 4" bore =302ci
Old 01-07-2008, 07:44 AM
Banned
I would use screw in studs at that high of an RPM range. Along with super stiff spings, and good pushrods. The super victor is way overkill for that engine, hell a Performer RPM would run fine at 7,000 RPM in a 283. Also IGNITION becomes a limiting factor at those engine speeds. Hitting 8,000 RPM in a small block is not as easy as it sounds.
Old 01-07-2008, 03:50 PM
Yup Richard Steward that combo would be nice, but Im not planning on dumping a pile of money into this motor. Ill be using the stock bottom end, freshened up with rings and bearings, and the stock 60cc cylinder heads.
In short, is my thinking correct that a short lift, long duration cam will be somewhat easier on valvetrain parts? Or will it come apart immediately?
Old 01-08-2008, 07:30 AM
Banned
as long as you don't rev it above 6500 you'll be fine... but if you really want to rev to the moon then you need to pay for the space shuttle.
New to the forum, Cam choice question kmkchris1 Engine 14 01-31-2007 01:42 PM
XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 Warrant Engine 10 03-01-2006 03:58 PM
cam for a 283 nigelh Engine 6 07-14-2005 08:33 PM
Cam choice,, Please help!! Lthompson Engine 23 02-09-2005 07:05 PM
Cam for chevy 283 345coupe Engine 8 10-18-2003 06:04 PM
