283 cam preferrence
I have built a really cool ratrod, chopped 29 Ford pickup. Installed a stock 283 with Powerglide from 67, I think Impala. Well maybe not fully stock. It came with Holley 650 spreadbore. I can tell the engine was rebuilt at some point, but I believe they used a stock cam since it runs so smooth (uh, too smooth). The engine runs great as is, but I would like to little bit more umph. I'm really not looking to more HP as it does fine as is since the rat is so light, but would like for it to sound better than a sewing machine as I cruise slowly at car shows, etc. A low to mid range cam maybe. I don't plan to change heads or intake. Just a cam for better sound. Just wondering if anyone can give me any suggestions. Example of lift, duration... brand.
Thanks, Bob |
We really need to know which 283 you have, approximate weight of your rod and what gears you're running. Just off the top of my head though the Summit 1103 might give it the idle you're looking for without totally killing your bottom end. Here's alink to a video of one in a 305........
Summit 1103 |
You asked what engine, weight, and ratio. I was afraid someone would ask. All I know is it's a 67... i think. weight? Best guess about 1600 to 1800 lbs. Ratio. Rear end came from Astrovan. I think it's about 3.5:1. As it stands now, the rat is a little slow off the line, but gets going above 15- 20 mph. I consider it totally acceptable on power as is. But I'm not changing the cam to get better line start. In fact, if changing the cam for better "sound" results in a little less performance off the line, I can live with that. I'm not going to enter any drag races. Not this truck anyway. The problem now is... it sounds like your great aunts car who only drives on Sunday. Ii just want one that sounds cool. No plans to do burnouts. Thanks.
I don't know how much compression is in your motor or whether you want to adjust the valves from time to time, how 'bout the 283ci/290 hp Fuelie cam?
I think they used to call it the Duntov 18-20, or something like that. Solid lifters, a little on the noisy side ( but in a good way ). Maybe something comparable in a modern design, will give your rat rod a decent boost. |
In order to run the cam you want with the racey idle sound you will have to replace the torque converter.
You will need a 9" or 10" "3500 stall" converter. other wise it won;t idle in gear. You need the looser converter coupling at idle for these types of cams. The low initial acceleration will be much better too. A stock torque converter will not work. Isky 201268 or isky 201278. www.iskycams.com you will need to recurve the distributor also. These cams will give the sound you want. |
Hey F, did you happen to notice he said it`s a 283? It`s easy to make a 283 lope since it`s small on the cubic inches. Also he doesn`t know what the compression ratio is or what mods may have been done to it. He said he wanted a cam, he didn`t say he wanted to do alot of work which would be required on both cams you mentioned.
If it`s just a basic lope he`s after then a Comp 268H will do that with .218 duration. |
The results with the isky cams will be worth the effort and new high stall converter.
The little 283 will benefit from a distributor recurve and a high stall conerter reguardless, even with the 268H cam. The isky cams will sound better. This way you'll only have to do it once. |
I would look for a cam with 106 to 107 LSA and with a duration of 212 (at 0.050") on the intake and 218 on the exhaust.
A 283 doesn't need much cam to make it lope. Plus the narrow LSA really makes it extra lopey at idle then helps it make better mid range power. It should be ok with the stock stall, but I would change it to a higher stall as soon as possible. and change to a th350 at the same time. run 25 degrees of timing at idle, 37 to 38 total. Use an adjustable vacuum advance canister to add another 10 degrees. You have headers, right??? if not, get some. |
454 took the words out of my mouth. I was going to say use a cam around .212 @.050 as it would be ideal for a little 283 and should lope as the small cubes are easy to make lope. In my 4.3 V6 with TBI, I have a isky computer hydraulic roller cam in it with .204 .209 duration and at 675 RPM at idle it lopes nicely. Even so the 4.3 is a 350 with 2 cylinders whacked off, it`s still less cubic inches overall, mine is bored .030 which puts it at 266 cubes, it`s still 84 cubes less.
This would be my pick, it works with stock compression ratios and pretty much stock pieces. It`s single pattern cam which I perfer over a split pattern. http://www.summitracing.com/parts/CCA-CL12-206-2/ |
These are all great suggestions, and I much appreciate all the replies. Double is right. All I want is a bit of lope without having to do anything else to the engine/trans. Keep in mind, this is a ratrod with the goal of build it quick, cheap, and keep it simple. That I have done, but that engine, well, it's just, uh the sound, it's just so darned smooth. Plenty of power for its weight and safety, so sacrificing a lttile low end performance is not a concern. I believe your suggestions have just about narrowed it down, but I welcome more. Thanks a bunch.
