283 crank in 400??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2011, 12:39 AM
MAKE EM STICK AND E.T'S QUICK
283 crank in 400???
i was just curious if anyone has ever heard anything like this being done? ridiculous rpms seem possible.
Old 01-18-2011, 12:44 AM
DoubleVision's Avatar
That would require some really thick bearing spacers as 283 cranks were all small journal 2.30 inch size and 400`s are 2.65 inch. I`m sure somebody`s did it and likely used a large journal crank from a 302. Placing a 327 crank in a 400 is popular. However, the stroke doesn`t dictate how high it`ll rev, The valve train does. It would work rather well for something that requires constant high revs such as track racing, but for street use it`s almost worthless.
Old 01-18-2011, 12:47 AM
yea i meant to say 302 i was reading a dif artical and was discussing 283's sorry. but i knowthe top end would determin but the bore to stroke would be pretty damn good i think for a 1/4 mile motor.
Old 01-18-2011, 12:59 AM
Good for a quarter mile, not really. It would have to have really deep gears in the 5.50:1 or lower range. If a guy comes along with a 350 built up similiar he`ll blow your doors off. You can`t beat cubic inches, no matter how high you can rev. When I was younger I used to dream up all kinds of short stroke high revver combo`s. My instructor at tech college ran a high revver in his racing days using a 283 bored to a 4 inch bore making it a 302, biggest solid cam he could get, dual quads, 5.13 gears, 3 speed GM manual tranny. His words were "I never lost if it didn`t break, but it broke alot" He would take it up to the line, rev it to 9500 RPM, side step the clutch and hang on.
I seen many a high revver over the years at the drag strips, they always lost and why was because they were running 5 speeds, and since it`s geared so deep and tachs so fast they couldn`t shift it fast enough. The 3 speed my instructor used was the trick, he only had to shift twice and he was in 1:1 direct drive (3rd gear) Anyways, as I got older, I realized what I just said before, no matter how high you can rev, it won`t beat cubic inches and there`s no point spending thousands of dollars on custom pieces trying to make it rev that high and stay together only to get out run by a bigger engine with half that amount invested.
i do realize there would be next to no bottom end and your right about the street driving, i heard storys about those 302s not being the "best" mills to put around town. but with that crank the rotating mass would be drasticly less than the 3.75" stroke. sorry responsive rather than high revving
Old 01-18-2011, 01:06 AM
double vision please dont think im arguing or anything like that. im 22 and just really love cars its in my familys blood. n just wanna learn. i understand theres no replacement for displacement but i was thinking the faster u got the crank turning.....
Old 01-18-2011, 05:28 AM
Banned
Destroking can help some engines, but not in the example you give, a really oversquare bore/stroke isn't needd for a good race engine. If it was no one would race 383's and they're everywhere!
You need to consider the entire package, a LOT of people have trouble with that idea.
Old 01-18-2011, 07:48 AM
AP brings up a important lesson that I`ve stressed many times, think of the whole package, don`t count on one thing to be the ultimate advantage.
To look it with this prospective, a engine isn`t one part, it`s many, and it all has to work together as a team to make max performance. Counting on one part to do so doesn`t work. Edelbrock pushed the envelope hard in the 80`s when they released packages of a intake, carb and cam, all matched to work together. Since a engine is many parts, it`s a team, one part doesn`t do it all. As AP mentions, many look at a engine as only 1 thing.
Holley still carries a package of carb, intake, cam and heads, with headers and a good ignition on a 350 engine, it`ll make over 400 horsepower.
This outlook of one thing is what causes many to bolt on a carb or a cam that`s way too big. Some, especially the younger generation get swallowed by what we call "more`s law" they believe, if some is good, more must be better. They`ll try and stick a 850cfm carb on a stock 305 and wonder why it don`t have any power afterwards. Or install a monster cam in a 305 then wonder why it won`t idle, has no power and the power brakes don`t work anymore.
What crank keys do I use for SBC crank? eric32 Engine 2 02-08-2009 07:36 PM
what crank hammered51 Engine 1 01-23-2008 04:37 PM
ground 400 crank or new 383 crank? backyard71nova Engine 10 09-12-2007 06:13 PM
Scat 9000 crank VS stock 400 crank? MOORESPEED Engine 5 03-03-2005 10:54 AM
4ma crank vs stock clevo crank carnell Engine 1 08-17-2003 05:56 AM
