283 crank ???????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2005, 12:34 PM
65 c10, 283 tbi, 700r4, pb, ps
283 crank ????????
I have a 283 that haves a crank that has two notchs on that flange this site http://www.carcraft.com/techarticles/989/ said that 283 came with round flanges only do i have a 307 crank?????/ thanks
Old 04-28-2005, 01:44 PM
poncho62's Avatar
Wiki Edits: 5
The 307 has a longer stroke.............measure it.
If it has a 307 crank, you have a 307.
The 283 has a 3" stroke, if it's longer, its a 307/327 crank.
Old 04-28-2005, 01:46 PM
johnsongrass1's Avatar
Race it, Don't rice it!
307's have a 3.25 stroke and the 283 has a 3.0. Just measure the throw, calculate the math, and you'll get your answer.
Old 04-28-2005, 01:48 PM
Last journal entry: PICTURE TEST
numbers
What are the numbers on the crank????
keith
Old 04-28-2005, 06:21 PM
jesse01's Avatar
mini me
307 were also med. journal crank as for the 283 it had a small journal of 2.300
J
Old 04-28-2005, 08:30 PM
the crank is in the truck. do ya no what crank had two notchs?
Old 04-28-2005, 09:07 PM
MI2600's Avatar
Member# 3287
I've got a 283 crank with a flange that makes it look like a 350! I guess it got mixed up at the foundry or something.
Check the casting number. That's your only sure way to tell.
Old 04-28-2005, 09:13 PM
thanks ya'll
Bearing Spacers- 283 crank into 350 block jhs914 Engine 13 07-18-2009 10:06 AM
283 Harmonic Balancer JamesD Engine 29 03-14-2007 06:36 PM
283 stroker (307 cid) question Viking427 Engine 4 04-04-2005 11:40 PM
283 crank in 400 block.. FataL Engine 4 12-06-2003 05:06 PM
283 / steel crank/ trans selection el Transmission - Rearend 1 08-20-2003 02:10 AM
