283 crank journal question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2008, 01:55 PM
is there a large journal for a 283
Old 01-13-2008, 02:02 PM
no only small
Old 01-13-2008, 02:17 PM
is there a diff from the chev and the gm these is the shaft number gm173876768
Old 01-13-2008, 03:18 PM
DoubleVision's Avatar
Every shaft, head, intake, be it chevy, pontiac, buick, Caddy, Oldsmobile, they all had GM casted on them as they were all a division of GM.
Old 01-13-2008, 03:30 PM
junior stocker's Avatar
283 crank
NO large journal 283 cranks, but there are "thick" bearings to put 283 cranks in large journal blocks. I see you're over on JJ.com looking for a 283 crank also. What's your plan? You should be able to find a 283 crank in Ohio, and should be able to get a crank kit from any auto parts outlet; or go to any automotive machine shop; they will probably have several "waiting" to be used.
Old 01-13-2008, 08:41 PM
Put a 69 302 crank in a 307 block...You've got a large journal 283
Old 01-13-2008, 09:20 PM
MI2600's Avatar
Member# 3287
TRW used to sell thick bearings and/or spacers.
I don't think I would use up an original 302 crank for anything other than a 302!
Old 01-14-2008, 06:08 AM
302 Z28's Avatar
Right, try and find one of those .
Vince
Old 01-14-2008, 08:52 AM
Couldnt you have the journals welded up and then machined back down to the size you wanted either medium journal or large journal? I would liike to put a 283 crank in a 400 block to make an 11,000rpm screamer, might not last long but it would be fun while it lasted.
Shane
Old 01-14-2008, 11:59 AM
"don't think I would use up an original 302 crank for anything other than a 302!"&
"Right, try and find one of those "
That's, why I ,put a smiley after my comment...
I think there are aftermarket 3" cranks available. Probably in either 350 or 400 journal sizes.
JA
Old 01-14-2008, 12:19 PM
Kind of off topic but the l99(baby lt1 4.3 v8) used a 3 inch stroke crank, so someone could make an lt-302 if they wanted too.I personally feel that this should have been an option on the lt1 z28s.
Shane
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 10:51 AM
Small Journal or Large Journal Crank ???? S10 Racer Engine 3 12-12-2007 12:44 PM
283 Heads Question budthespud Engine 6 06-07-2007 07:01 AM
crank question superrican Engine 3 01-01-2007 08:58 PM
350 Crank & Rods Question Mustangsaly Engine 12 11-02-2006 07:20 PM
