OK, if I didn't give a hoot about the fact that most everyone on this board was suggesting a mild 350.....and I just had to have a 283, this is what I might do with it. Damn the cost, full speed ahead.......
Check main bearing bores for being round and parallel. Correct as necessary.
Bore and hone cylinders for +0.060", using torque plates and the proper stone and procedures for the rings used.
Registering off main saddle, cut block decks for 9.002" block deck height.
Use these pistons....
KB Pistons for Automotive Applications
With these gaskets....
Fel-Pro Performance Head Gaskets Q1003 - SummitRacing.com
To bolt on these heads....
Trick Flow® Super 23® 175 Cylinder Heads for Small Block Chevrolet TFS-30310001 - SummitRacing.com
Rebuilt Chevy 5.7 SJ rods will work fine, or you could opt for some bulletproof hardware like these offerings from Scat....
Scat Pro Stock I-Beam Connecting Rods 2570020P - SummitRacing.com
Mount this carburetor.....
Summit Racing® Remanufactured Quadrajet Carburetors SUM-210216 - SummitRacing.com
(Chosen for the tiny little primary throttle bores)
Onto this spread-bore Weiand Street Warrior intake manifold....
Weiand Street Warrior intake Manifolds 8126 - SummitRacing.com
Power range, 1500 to 5500, matches the camshaft operating range....
Install this cam straight up on the marks.....
12-210-2 - HIGH Energy
Or this cam....
Or this cam....
113941+crane+cam - JEGS High Performance....
Or this cam....
Melling 22203 hydraulic flat tappet
214/224, 288/298, 0.444"/0.466", 107/117/112, intake closes 34 @0.050"
Or any other cam that you like that has these kinds of numbers....
With these lifters....either original or V-Max. Call Rhoads and talk to them about the best choice for your combination. 520-229-9375....
Part Numbers
Use 1 5/8" long-tube headers with X or H pipe before the mufflers.
Use 14" x 3" or 4" air filter element.
Find true TDC #1 while you are reassembling the motor. Mark the damper if it is off or buy a rebuilt damper from these guys.....
Damper Doctor Online - Your source for Harmonic Balancers, Motor Mounts, & Drive Shaft Supports
Static compression ratio with 56cc heads, 6cc flat-tops, 5.8cc gaskets, 0cc piston deck height and 597.9 cc's in the cylinder will be 9.81:1. Dynamic compression ratio above 3500 rpm's will be 8.580:1 with the intake closing at 35 ABDC @0.050" tappet lift. Dynamic compression ratio between just above idle and 3500 rpm's will be roughly 8.81:1, factoring in a 10 point drop in duration and figuring that the intake valve will be closing closer to 30 degrees before the lifters pump up than the 35 degrees after the lifters pump up. Not trying to muddy up the water, just taking another route.
After reading DCR results from several board members lately, I think I have been leaving some on the table using 8.5 as a good figure off the KB calculator and that with the very tight 0.038" squish (piston pops out of the deck by 0.003" with a 0.041" gasket), this motor should run fine on pump gas. I have seen fellows running 8.9 on the KB calculator with no detonation on pump gas, but I have been reluctant up to this point to use a higher DCR than 8.5.
