283 engine code help!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2012, 08:45 PM
mcreasey's Avatar
Hey guys. I have the following code on my Chevy 283 block. This number is on the front passenger side of the block where the head meets the block. Any help as to estimated year and car model would be greatly appreciated!!!
F0902we.
F= flint mi
0902= September 2nd
What is "we"????
How can I determine a range of years??
Thank you!!
Matt
Old 09-17-2012, 08:58 PM
DoubleVision's Avatar
1965 WE 283 M/t - 175 2 C-10 to 25
1968 WE 307 Powerglide - 200 2 C-10
Old 09-17-2012, 09:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
F0902we.
F= flint mi
0902= September 2nd
What is "we"????
Thank you!!
Matt
The "WE" is called the suffix code but you might have already known that.
Unless you are positive you have a 283, you need the date code (help on this and the other codes is here) in order to determine which engine you have, since there are two engines (one 283 and one 307) w/the same suffix.
Good luck.
Old 09-23-2012, 09:34 AM
It's easy to tell a '65 283 from a '68 307.
The '65 block will have an extra hole near the distributor hole (for the draft tube) The '68 block will NOT have that hole. JA
engine code booberloc Engine 2 07-19-2011 09:27 PM
GM Engine Code bscooter Engine 8 12-11-2010 07:54 PM
engine code coorsroc Engine 2 10-20-2008 08:45 PM
engine code? yragat Engine 2 11-09-2007 08:25 PM
engine id code cdn tpi engine sanders20052 Engine 0 11-04-2005 07:57 AM
