-   -   283 engine identification help (http://www.hotrodders.com/forum/283-engine-identification-help-229589.html)
Soonerseaj 02-15-2013 10:27 AM
The serial number on the passenger side of the block of t he 1957 chevy I just bought is VOII1WA. Any idea what year and size it is?
philshevlin 02-15-2013 10:43 AM
A good site to help ID it:
Small Block Chevy Engine Block casting and code identification
cobalt327 02-15-2013 02:09 PM
ID Chevy engines
If it's a 283, suffix code "WA" is for a 1965, '66, or '67 Chevy truck, RPO L32, 2 bbl w/manual trans.
But the same suffix code is also used for a '68 307 and a '69 350 SBC, possibly others as well.
That's why you also need the casting number and date code from the block to narrow it down, although the difference between a small journal and large journal SBC block is pretty easy to spot if you know what to look for. That could narrow it down to a 283/307 or a 350.
cal1320 02-15-2013 05:42 PM
Are there bolt holes on the side for motor mounts? If it's a 57, it won't have them.
