283 engine identification help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2013, 11:27 AM
The serial number on the passenger side of the block of t he 1957 chevy I just bought is VOII1WA. Any idea what year and size it is?
Old 02-15-2013, 11:43 AM
A good site to help ID it:
Small Block Chevy Engine Block casting and code identification
Old 02-15-2013, 03:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ID Chevy engines
If it's a 283, suffix code "WA" is for a 1965, '66, or '67 Chevy truck, RPO L32, 2 bbl w/manual trans.
But the same suffix code is also used for a '68 307 and a '69 350 SBC, possibly others as well.
That's why you also need the casting number and date code from the block to narrow it down, although the difference between a small journal and large journal SBC block is pretty easy to spot if you know what to look for. That could narrow it down to a 283/307 or a 350.
Old 02-15-2013, 06:42 PM
cal1320's Avatar
Are there bolt holes on the side for motor mounts? If it's a 57, it won't have them.
283 engine kcsodafiz Hotrodding Basics 25 01-14-2013 12:53 PM
Engine Identification Help brunelle99 Hotrodding Basics 2 07-06-2011 11:25 AM
Engine Identification DaveNH Engine 1 09-27-2007 01:03 AM
283 identification 7chevelle1 Engine 6 12-06-2006 12:42 AM
Engine Identification internetcarguy Engine 4 01-04-2006 08:02 PM
