Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 with heads
Thread: 283 with heads
Old 08-03-2012, 10:02 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by rambler454 View Post
I've heard Vortec heads are bad about cracking? I need to send the engine to a machine shop. anyways any ideas or engine combo's like pistons and such would make a good street engine?
Only the junkyard vortecs are likely cracked.
The trucks these came on had a intake gasket cooling
problem that caused the engine to loose coolant and overheat.
That what makes any head crack.
if you go for vortecs buy new castings.
The only vortecs in the junk yard or on evil bay are cracked ones.
The good ones get rebuilt and reused
Buy new and you won't get stung.
The GM bowtie vortecs rock.
The engine quest EQ lightning vortecs are very good too.
