283 heads ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2010, 07:13 PM
tbbronson's Avatar
283 heads ??
Hey Guys- need some help here- I have a good 1958 Vette' 283 engine that's missing the heads. My Buddy has a real nice set of casting # 462626 350 heads he'll give me,... but I'm concerned about the performance- like- would the compression be too low ?? Any input on this or maybe another post somehere else where this subject's been covered already ??
Thanx alot...
tbbronson in Orlando...
Old 07-01-2010, 07:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanx alot...
That number doesn't show up in my info (have info on 462624- large chamber, crack prone), but if they're large chamber heads for a 350, they will not give enough compression.
If they are the small chamber heads, they may be OK. The heads from a 305 have about the right chamber size. Casting 416 are said to be a decent head, w/1.84" x 1.5" valves. There is a 305 Vortec head c/n 12558059, that shows some potential, also.
Old 07-02-2010, 04:52 AM
tbbronson's Avatar
283 heads ??
327... thanx alot- yeah..that casting # is throwin' me... can't seem 2 find the last 6 digit in SBC casting research either- but the # is real plain & clear...
Oh well... I do have a 305 too.... maybe I'll research the #'s on it & use those heads...
Thanx again man...
tbbronson
Old 07-02-2010, 10:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Pretty funny- I googled the casting number (I seldom use the site- just too much BS usually) and got several hits. Lo and behold, they were your posts! From here and another site. I thought at first, "heck these heads must be common". But I guess not.
I did see one other mention of the head c/n- but it was an engine on eBay that had both “HEADS# 462626”, then in the description “HEAD'S # 140144116”, so no idea what he really has.
But the main thing is, if they're large chambers, like 72-76cc, they're too big to do you any good.
What is the c/n of the 305 heads? Hopefully they will be something w/the 1.84" intake valves.
If Revmaster Machine Shop is still over on Old Winter Garden Rd., give them a call for heads or head work. Down the street from them is Fosters junk yard. It's a pull-it-yourself 'yard, good parts and prices.
Good luck.
Old 07-02-2010, 12:08 PM
tbbronson's Avatar
283 heads ??
Thanx agin' 327.... Yeah- gotta' pull the covers & get the #'s off the 305- am bein' told by a coupla' gear-heads that they could be a lil' small for the 283 & offer 2 much Compression... am gonna' research the C.C.'s of the 350 heads a lil' more ( as well as the c.n.'s)... looks like I could have several options- including the junk yard U mentioned- also- Nat'l. Cyl. Head down behind the Citrus Bowl (U mighta' know it as the Tangerine Bowl) mite can advise me about 'em too....
Thx agin'....
tbbronson
Old 07-02-2010, 12:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Absolutely! I can't believe I forgot about them!
They started doing a better grade of valve job, if you request it. This was quite a while ago, but I'm sure you know or can get the details. I believe it involves a 3-angle cut and maybe a bowl "ream" below the bottom 70º cut?
Anyway, I used to take them my bare heads after porting and I had a older Puerto Rican man named Angel who'd give them "special" attention- he was the shop boss then in the cylinder head machining department- probably retired by now. I was always good for a decent tip, and he took good care of me.
I used Revmaster for crank turning and block boring much more than head machining (I was in Ocoee, West side Orange Co.). I can't believe I completely forgot about NCH, though!
Old 07-02-2010, 12:42 PM
tbbronson's Avatar
283 heads ??
Ha !!..Well we all sometimes suffer from Brain Farts 327 !!! (LOL)
When did U leave the City Beautiful ??
I was born here 60+ years ago, raised in College Park ( Edgewater 68'), and now live off Apopka-Vineland Rd. in W. Orange County...if I was on the west side of A.V. I'd be in Ocoee, but am on the east side of it ( by 600 ft.), 1/2 mile south of Clarecona Rd. ( remember that 1 ??)...
I've heard good things about Revmasters, but no personal experience...
And yes- I had N.C.H. do several head jobs 4 me in the past & always got the 3-angle grind... didn't know Angel, but they always took care of me as best I could tell...
Thx.
tb
Old 07-02-2010, 01:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thx.
tb
I left FL about 14 years ago, but I still visit. I know the Clarcona Rd./Apopka-Vineland Rd. area well!
Take a look at Fosters, they used to have a good supply of junk on hand at all times. By the time I left, SBC engines were still plentiful, hopefully they still are. I don't know by now what they might have, though.
Old 07-02-2010, 01:38 PM
tbbronson's Avatar
283 heads ??
.. will check with them, although the big movers now I would think are the Japanese 4 bangers, etc..
Thx agin'.....
tb
Old 07-02-2010, 02:52 PM
tbbronson's Avatar
283 heads ??
What is the c/n of the 305 heads? Hopefully they will be something w/the 1.84" intake valves.[B]
Good luck.
327- yeah... a closer look @ the 350 heads revealed that last digit was a 4 after-all....so they're 76 C.C. C.C.- shoots the C.R. all 2 heck... oh well...
But- I slipped off the V.C.'rs on the 305- cast # 14022301- indicates they're 1.85 & 1.5 valves- but couldn't find the C.C. c.c.'s.... U know where I can look 4 that ??
Thx.
tb
better cylinder heads for my 283 Berliner Bel Air Engine 5 10-29-2007 07:41 PM
chevy 305 heads on a 283 hotrodvotion Engine 10 08-31-2007 11:14 AM
283 heads on 350 70 nova Engine 5 11-09-2005 08:26 AM
283 heads Blob Engine 3 10-25-2003 02:02 PM
283 w/305 heads. 305 head gasket? malibu65ss Engine 2 01-16-2003 02:07 PM
