283 with heads
i got a 283 and heads were separate and i can't find the casting number online anywhere. they say 378450?
They are low perf 305 heads.
They will run on your 283 but don;t expect much power. If you want power froma 305 head on a 283 get some #4416 heads and home port them 1.94x 1.60 valves help too. Vortec heads work very well on 283's too. mill .040" off the decks and install with a thin felpro 1094 gasket. the 450 casting heads will be lame on any motor including 283's. |
Another nice head to use on a 283 is the L-98 aluminum heads from corvette and camaro 5.7L TPI motors casting number ends in 113.
Also found on the ZZ4 350/355hp crate motor. Especially good after been ported to increase flow. 58cc chambers 1.94x 1.50 valves. Good flow and power when ported. |
I've heard Vortec heads are bad about cracking? I need to send the engine to a machine shop. anyways any ideas or engine combo's like pistons and such would make a good street engine?
The trucks these came on had a intake gasket cooling problem that caused the engine to loose coolant and overheat. That what makes any head crack. if you go for vortecs buy new castings. The only vortecs in the junk yard or on evil bay are cracked ones. The good ones get rebuilt and reused Buy new and you won't get stung. The GM bowtie vortecs rock. The engine quest EQ lightning vortecs are very good too. |
| Heads for a 283 | Sapper | Engine | 22 | 02-05-2012 09:36 PM |
| 283 heads ?? | tbbronson | Hotrodding Basics | 9 | 07-02-2010 02:52 PM |
| 283 heads | Blob | Engine | 3 | 10-25-2003 02:02 PM |
| 283 heads | 70 nova | Engine | 2 | 02-17-2003 06:16 PM |
| 283 heads | Frank50 | Engine | 3 | 02-15-2003 11:25 PM |
