Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 Heads Question
Old 06-06-2007, 10:10 PM
baddbob baddbob is offline
You definately need those small chambers on a 283, 55cc would even be better. I'd also use a steel shim head gasket like the factory did or again you'll lose compression. You should be able to open up the intakes for 1.94 valves and do some port work for more power.
