Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 Heads Question
Old 06-07-2007, 08:01 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
I agree, a set of casting number 416 heads will work nicely, best thing is there cheap and the junk yards are full of`em. They come with 1.84 intake valves, you can have these moved up to the 1.94 intake size but if you are to do so have the chamber deshrouded. But honestly, since it`s a 283, I`d just use the 1.84 valve, as it`s better than the 1.71 valves the 283 heads came stock with.
