283 identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2006, 09:28 AM
283 identification
I Acquired A 283 Sbc, With Manual Trans. It Has A Casting Number 3849852 On Back Of Block. On Front Engine Pad It Has The Number Fo6i20f Wondering If Anyone Could Tell Me Some Info Or Possibly What This Engine Was In
Old 12-03-2006, 11:51 AM
DaSouthWon's Avatar
I put up the tools against$300
3849852....283...57-66...2 bolt main (mortec.com)
I'll look and see what I could find on the other code. Did you see a date code anywhere?
Old 12-03-2006, 11:56 AM
DaSouthWon's Avatar
Engine ID Code Example: V0101CLJ - (V = Plant, 01 = Month, 01 = Day, CLJ = Engine Suffix Code)
Another example: T0830CTY - (T = Tonawanda, 08 = August, 30 = 30th day, CTY = 1970 396 Camaro, 375 hp, 11.0:1, TH400)
Code Engine Plant Code Engine Plant
F Flint (Motor) S Saginaw Service
H Hydramatic T Tonawanda
K St. Catherines, Ontario V Flint (Engine)
(McKinnon Industries Canada)
M GM of Mexico
courtesy nastyz28.com
Old 12-03-2006, 12:01 PM
DaSouthWon's Avatar
F= 1957 283 Powerglide - 2 cars & Vette
Old 12-05-2006, 10:51 PM
thanks for the reply, on the engine info. another interesting thing about this combo is that it has a parking brake lever made on side of transmission. there is a drum that mount in between trans and driveshaft , that has brake shoes on the drum which a linkage attaches to the lever on side of trans
Old 12-05-2006, 11:23 PM
that type of setup is for 1 ton+ trucks. 57 283 has no side motor mounts check that out sell it to someone that is restoring a 57' chevy or corvette.
Old 12-05-2006, 11:42 PM
i didn"t notice the side mounts but will look tomorrow. i does have what appears to be some mounts on front of engine, on each side of timing chain cover, it looks kinda like a rubber isolator on a stud. it"s for sale if anyone interested.
283 to 302 jakester Engine 16 05-22-2007 08:41 PM
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
283 piston alternitave jeff of nc Engine 3 10-10-2003 04:33 PM
high performance 283 steve Engine 2 06-22-2003 03:25 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 12:48 PM
