283 just wont run right - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2004, 09:37 PM
hunt101's Avatar
Learning something every day
Last journal entry: Adding some tunes
Ok, I just bought my first car (62 Impala 4dr with a 283). I got it to run on 7 cylinders but I just cant think what might be wrong. It started on about 5 cylinders and picked up 2 more when I ran it wide open. It has a new carb, fuel pump, and distributor cap. The only things I have found so far is the carb is not tuned and is missing one mounting bolt, and the fuel line is kinked. Any help would be appreciated.
Old 11-15-2004, 09:48 PM
Mad Maggot's Avatar
The lean mean donut machine
have you checked the spark plugs and their wires? They may need to be cleaned or replaced.
Old 11-15-2004, 09:52 PM
hunt101's Avatar
The spark plug wires are new and I pulled out one of them and they looked fairly new. It had a stong spark so I am going to check the rest of them. Also, could someone tell me if the cylinder numbering is the same as most chevy engines?
Old 11-15-2004, 10:01 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
Replace the plug in the bad cylinder. Or you can try moving it around and see if the miss moves as well. Try the same with the plug wires. The cheap wires are easily ruined. If the miss is still in the same place after this I would suspect a bad valve. It wouldn't hurt to fix the missing bolt and kink in the fuel line.
Old 11-16-2004, 04:46 AM
check the compression ,, blown head gasket between cylinders or valves ,, ?? any choofing noise out exuast at idle ??
