283 Main Bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2006, 08:34 AM
283 Main Bearings
I am installing a newly machined crank shaft into a 283 Chevy engine. The specs call for .003 to .011 end play. The dial indicator indicates I have .014. I need a source of some one who makes a .020 over main bearing with a .010 over thrust face on the rear bearing. I have found bearing with these dimensions for a lot of other engines such as the 327 and 350 but I can't find any for a 283 small block. Does any one have a phone number for some one who might have this item??
Thanks, Tom
Old 02-11-2006, 08:40 AM
King of my Man-cave.
I have looked but I have been unable to find a manufacturer that supplies oversize (length) thrust bearings for the small-journal SBC.
taom
Old 02-11-2006, 08:52 AM
coldknock's Avatar
I can't find anything in my catalogs either.
I may be mistaken but I believe that the main journals on 327 and 283 cranks were the same size. Both cranks came with small or large rod journals depending on the year but I think that the mains were all 2.445. If that is the case the 327 listing you found will work.
Let us in on the source and part # if ya don't mind.
Larry
Old 02-11-2006, 09:48 AM
Larry
I'm guessing he found a listing for the large journal 327, which would also show the 350 with it.
tom
Old 02-11-2006, 11:58 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Check with your local engine parts supplier. A lot of bearing company's build a over size thrust bearing but don't list it in normal catalog because it is a special order item only. Keep in mind you will have to have your crank thrust ground by a crank grinder.
chevy 283 rear main seal. Brother's57 Engine 4 01-23-2006 04:16 PM
SBC Block Questions Mustangsaly Engine 14 06-23-2005 10:14 AM
Main Bearings k-star Engine 5 07-22-2004 04:41 PM
Main bearings fried NorthStar Engine 8 02-18-2004 02:54 PM
.001 oversize main bearings from factory crshrmn3 Engine 2 01-02-2003 07:46 PM
