Thread Tools Search this Thread share on Facebook
  #1
Old 12-21-2011, 10:26 PM
oldscule oldscule is offline
283 main clearance problems
1,2,3,and 5 measure .0015 to .002. 4 on the other hand measures .006. I checked the crank and the journals measure the same. Problem with the block? Thinking about moving bearings around and see if the problem follows or stays. I guess the main question is can I run it if it is .006? What would happen?, how low would it bring the oil preasure?
Register now (free) or login to remove ads
Old 12-21-2011, 11:10 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
First step is to check the bearing itself. leave the bearing in the cap and remove the crank then tighten the main cap down and measure the bearing top to bottom, then switch in another set of bearings and measure again. If it`s just as simple as the main bearing then no problem. But if the clearances come up the same the issue is in the main cap and the block will likely have to be line honed. I`ve seen large journal small blocks be ran with one main bearing clearance excessive and it ran a long time, but I certainly don`t recommend it.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "283 main clearance problems"
ThreadThread StarterForumRepliesLast Post
Main & Rod Bearing Clearance to oil weightdbilskiEngine905-18-2011 07:55 PM
main bearing clearanceGMREngine1005-31-2008 09:16 AM
87 Chevy 350 TBI rod & main Clearance questionMustangsalyEngine305-20-2006 04:18 PM
SBC 350 Main Bearing ClearanceBuddyKEngine205-20-2006 10:16 AM
My 383 Buildup, Main Bearing Clearancecobra621Engine809-25-2005 03:49 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
