To 283 or not to 283? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-16-2012, 10:51 AM
painted jester's Avatar
Last journal entry: no big deal
Originally Posted by vinniekq2 View Post
PJs 302 in a mazda miata with a 5 spd would sure make the ferrari boys look silly
Years ago we put an 8,000 rpm 283 hilborn injected 4 speed in an Opel GT it was one of the quickest and Hairiest to drive cars I ever saw And it was street only No roll bar nothing with hot grooved 8 inch slicks LOL
Jester
  #17 (permalink)
Old 11-16-2012, 11:39 AM
vinniekq2's Avatar
holy crap,I remember my first slicks were a semi soft side wall with a two grooves cut into the surface. They cost me spider gears twice and 1 muncie.
  #18 (permalink)
Old 11-16-2012, 12:34 PM
My Buddy always ran radial slicks on an 11 second Roadrunner 440 4 speed. (it will be in my journal soon with the new Engine I built for him) I talked him into running bias belted and on his first run it hooked up so harsh and the front end lifted he went back to the Radials the next pass LOL! But it was the first time the car broke 10! Hes afraid something on the car will break and he drives it on the street (its not a drag car) He couldn't believe the difference in traction!!!!
Jester
  #19 (permalink)
Old 11-16-2012, 12:57 PM
BigEd36's Avatar
As pointed out very well by Painted Jester, to build your HP goal with a 283 will be more expensive than with a 350. Any budget 350 build with a mild cam, dual plane intake, 600-750 cfm carb, and headers will easily make 300 HP.
Here's probably the easiest 300 HP there is for $1819.95 with FREE shipping and a warranty! It's only $80 more with an Edelbrock Performer intake manifold. You would be hard pressed to build it much, if any, cheaper.
For $160 more ($1979.95) you can get the 2 bolt main 350 Vortec long block, again with FREE shipping. For $2019.95 you can get the 4 bolt main 350 Vortec long block with FREE shipping. These both upgrade you to factory roller cam. The 2 bolt main block will more than handle the HP level you're aiming for. A cam change to the GMPP #14097395 cam used in the 350 Ram Jet and HT383 (High Torque 383) engines puts you well into the range of your HP goal. Edited to add: This cam will work with the stock Vortec heads, lift is .431/.451, 196*/206* duration at .050" lift, 109* LSA (lobe spacing angle), really pumps out some torque in a Vortec headed engine.
  #20 (permalink)
Old 11-16-2012, 01:20 PM
How fast is fast enough?
Okay, for cheap power here's an EASY recipie.
5.3L gen III engine
LS1 or LS6 intake
LS6 valve spring swap
small cam regrind
mill your heads
tune and possibly injectors
even with stock manifolds you're well past your HP goal, probably spending between $1000-$1500 total, and will have a more durable engine with better street manners than if you built that 283.
Yes its that freaken simple and cheap.
  #21 (permalink)
Old 11-16-2012, 01:33 PM
Dunnp2:
Dyno tests May shock some on the little 302 especially in the higher rpm ranges but every day driving is not in these ranges ! So consider well what your driving will be!
HORSEPOWER NUMBERS
RPM 302 327 350 350 ('71)_ the legendary LT-1
3000 167 196 208 199
3300 184 210 232 223
3500 206 232 254 246
3800 233 261 283 275
4000 248 275 298 291
4300 272 297 318 311
4500 283 308 329 324
4800 301 324 341 340
5000 311 333 347 347
5300 326 344 352 355
5500 333 349 353 361
5800 347 347 350 362
6000 350 348 348 361
6300 353 352 348 353
6500 356 347 342 345
6800 356 339 329 332
7000 352 331 312 319
TORQUE NUMBERS
RPM 302 327 350 350 ('71)-LT-1
3000 292 332 364 349
3300 293 334 369 354
3500 309 348 381 369
3800 322 360 391 379
4000 325 362 391 382
4300 332 363 389 380
4500 331 360 383 378
4800 329 355 373 372
5000 327 350 364 364
5300 323 341 349 352
5500 318 333 337 345
5800 314 314 317 328
6000 307 305 305 316
6300 295 293 290 295
6500 287 281 277 279
6800 275 262 254 257
7000 264 248 234 239
What are your head casting numbers from your 283?
A few of my tips on 302s and 283s: you build a 283 get head gaskets that fit the bore of the 283 don't get generic over the counter gaskets that fit from 283 to 400 bores, Cross drill and chanfer your crank, if you can afford it Chrome The crank journals ( I can see an argument LOL) I do it But my 302s hit over 8000 rpm! Make sure the machine shop you go to uses torgue plates , for High rpm use shaft rockers or at least a girdle, Dont use aluminum rockers, Be precice on all balancing, Use floating pins, Use only forged pistons, I use solid flat tappet cams (I have my reasons but to each his own) Other guys on here can add more or Ill be typing all day LOL and many may disagree with what I say LOL!
AIRFLOW DATA CFM: head castings #s
In/Ex In/Ex In/Ex In/Ex
Lift 186 *461 492 487
.050 30/20 30/21 30/22 31/22
.100 58/45 59/46 59/47 59/51
.200 113/87 115/93 115/92 119/102
.300 158/120 164/127 158/117 173/133
.400 190/136 201/155 186/127 207/144
.500 205/140 211/168 200/134 213/146
.600 205/141 212/174 209/137 215/146
*461 heads eliminated for test due to obvious porting; 327 was run with 186 heads.
Jester
  #22 (permalink)
Old 11-16-2012, 01:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by dunnp2 View Post
Hey guys, my brother has an old chevy 283 block, crank, and heads that he's willing to give me to use for a swap. It's from between '58 and '62, casting code 3757519, two bolt mains. Things are a bit rusty so everything would have to be cleaned up before the build.
My question is: is it worth it? I'm looking for 300-350 hp, not afraid of turbos if that's the way to go. The other best option would be a junkyard LS1 which would be lighter and have more power, correct?
I have zero experience with american engines, so forgive me if I don't make sense.
Would it be cheaper to machine the block and buy parts to build the engine, or just buy a complete LS1 and be done?
One option that I don't think has been mentioned is to find a 1996-2000 L31 5.7L Vortec long block (an L31 Vortec long block includes the Vortec heads) or a 1986-up sbc 350 short block equipped w/the factory roller cam and lifters and add your choice of heads to it.
The ability to build an inexpensive engine that uses roller lifters is a real plus, given the poor quality of the over the counter motor oils and the possible cam break in problems w/flat tappet cams these days.
An engine like the Vortec long block w/a mild cam and a 4-barrel carb and intake and carb along w/headers and a reworked GM HEI distributor will reliably make your power goals w/o breaking a sweat, and can do it very inexpensively.
But whatever you decide, good luck and be sure to ask about parts and such first before shelling out your hard-earned money.
  #23 (permalink)
Old 11-16-2012, 02:30 PM
[QUOTE=painted jester;1612003]Dunnp2:
stock: Head flow data
------In/Ex-------In/Ex------In/Ex-------In/Ex
Lift-#186head- *461 head #492head #487head
.050...30/20........30/21.........30/22........31/22
.100...58/45........59/46.........59/47........59/51
.200....113/87......115/93.......115/92......119/102
.300...158/120.....164/127.....158/117.....173/133
.400...190/136.....201/155.....186/127.....207/144
.500...205/140.....211/168.....200/134.....213/146
.600...205/141.....212/174.....209/137.....215/146
The site is compressing posts making it hard to make columns and closing spaces in paragraphs So I straightened this out making it easier to read Its going to make it hard to post tech info Can someone fix this its important to some of us !!!!
Jester
  #24 (permalink)
Old 11-16-2012, 02:59 PM
BigEd36's Avatar
5.3L gen III engine
LS1 or LS6 intake
small cam regrind
mill your heads
Ap72, I have exactly ZERO experience with anything LS. I have an '88 Monte Carlo 4.3L V6. The engine is shot, I've been planning on repowering it with either a Gen I or a Vortec style engine. How much harder would it be to repower with the LS style? Do the LS engines use the same bellhousing bolt pattern, and the same engine mounts? Flywheel bolt patterns? A 5.3, 6.0, or 6.2 from a pickup might be an "interesting" upgrade if it's not to radical of a project.
Also, what specs of cam regrind would you recommend? What's the cost and where can you get the regrind done? Anybody whom you would recommend?
  #25 (permalink)
Old 11-16-2012, 05:15 PM
The bellhousing pattern is the same except for one bolt, the flywheels are different, engine mounts are different, Mike Jones can get you a good regrind.
A 5.3L can be bought for $500 or less. The larger ones cost a few grand.
  #26 (permalink)
Old 11-16-2012, 08:27 PM
BigEd36's Avatar
Cobalt327, thanks for pointing that out. A carbed Vortec engine is what I was suggesting but I never made the distinction between FI and carbed.
  #27 (permalink)
Old 11-18-2012, 02:54 PM
Mertz's Avatar
I am just finishing my 283 and will tell you that it was much harder to build than the 350's that my classmates were building. You don't have as many options for parts unless you have deep pockets and then some are still not what I really wanted. Guys were buying total engine rebuild kits with hyperutectic pistons for what I would have had to pay for just the pistons. I think I will end up with a nice engine.
  #28 (permalink)
Old 11-18-2012, 04:12 PM
Its nice to see people still building the Little Giant
If done right youll be happy! you building a stock type low HP or a stock 283-283 HP or hopping it up for High RPM & High HP?
Jester
283 ajh86 Engine 8 05-20-2008 04:32 PM
283 stray cat Engine 11 11-19-2007 12:25 AM
283! Bull_81073 Engine 3 07-23-2007 11:34 AM
283 crankshaft into 283 south65ss Engine 1 05-08-2007 08:25 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 12:48 PM
