There are many posts on here about 302s! A lot are mine! I posted cost to build and a couple of break downs!#1 Use the large journal 4 bolt 327 block with inserts for the small journal crank! or a 350 4 bolt block (small journal block is weeker) But this is an Idea of what your looking at if your interested! and a price Idea! I have a blue print to build a 302 but to hit over 400 hp in a 302 and the rpm ranges! you can do it much cheaper with a 350 and it will be more reliable! I build and run destroked 302 based engines I love em! But They are high maintenance!!
Jester
All dimensions in linear inches, except as noted.
Short-Block
Displacement: 306.1 ci
Bore: 4.030
Stroke: 3.00
Block deck height: Milled to 9.021
Piston deck height: 0.016 (below deck)
Piston volume: 17.9cc dome
Head gasket compressed volume: 8.9cc
Compression ratio: 11.75:1
Rod length: 5.7
Piston compression height: 1.805
Piston-to-wall clearance: 0.004
Main-bearing clearance (Nos. 1-4): 0.0029-0.0035
Main-bearing clearance (No. 5): 0.0026-0.0030
Rod-bearing clearance: 0.0026-0.0030
Rod side-clearance: 0.013-0.019
Crankshaft thrust clearance: 0.004
Piston-ring endgap: 0.020/0.018/0.026
Pressed piston pin-to-rod: 0.0008 minimum
Piston-to-head clearance: 0.055
Cylinder Heads
Valve size: 2.08/1.60
Combustion chamber volume: 64 cc
Port volume: 215/85 cc
Flow at 0.500 lift: 265/207 cfm @ 28 in H20
Flow at 0.600 lift: 281/217 cfm @ 28 in H20
Valvespring od/id: 1.509/0.697
Valvespring seat pressure: 135 lb @ 1.850
Valvespring open pressure: 325 lb @ 1.345
Valvespring coil-bind height: 1.100
Spark plugs: Autolite Racing AR3933, gapped at 0.035
Critical Fasteners
ARP head bolts: 60 lb-ft (Teflon sealant on threads, ARP lube under washer)
ARP main and oil-pump studs: Bottom hand-tight, back off 11/44-turn (oil)
ARP main stud nuts: 70 lb-ft (ARP lube)
ARP oil-pump stud nut: 60 lb-ft (oil)
ARP rod-bolt nuts: 40 lb-ft (ARP lube)
Pioneer balancer bolt: 75 lb-ft (oil)
Comp rocker-arm studs: 35 lb-ft (red Loctite)
Grade-8 cam bolt: 25 lb-ft (red Loctite)
ARP intake bolts: 30 lb-ft (RTV silicone)
Balance
Piston weight: 451.0 grams
Piston-pin weight: 130.0 grams
Ring weight: 48.0 grams
Rod-bearing weight: 44.0 grams
Bobweight: 1,641 grams
Camshaft
Type: Mechanical flat-tappet
Grind: Comp Cams Magnum 294S
Duration, advertised: 294/294 degrees
Duration, 0.050 tappet lift: 250/250 degrees
Lobe displacement angle: 110 degrees
Installed intake centerline: 105 degrees
Lobe lift: 0.356/0.356
Rocker arm ratio: 1.52:1
Valve lift at zero lash: 0.541/0.541
Valve lift at running lash: 0.519/0.519
Valve lash: 0.022/0.022 hot
Camshaft base circle: 1.150/1.150
Pushrod length: 7.900/7.900
Piston-to-valve clearance: 0.145/0.300
DREAM CHEVY 306 PARTS LIST
DESCRIPTION PN SOURCE PRICE*
LONG-BLOCK
Core 327 small-journal bare block EN-C327BA A&A Midwest $350.00
Core 283 forged-steel crank N/A Castillo's $125.00
Core 2.00-inch journal rods (8 required) N/A Dougan's $80.00
Speed-Pro forged pistons with pins (8 required) L2210AF-30 Summit Racing $411.12
Speed-Pro file-fit piston rings R-9342-035 Summit Racing $96.95
Speed-Pro Competition Series rod bearings 8-7065CH-10 Summit Racing $62.69
Speed-Pro Competition Series main bearings 138M-10 Summit Racing $55.99
Speed-Pro Competition Series cam bearings 2100M Summit Racing $35.69
Pioneer 6.72-inch-od SFI harmonic damper 872022 Summit Racing $149.39
Edelbrock head with valves (2 required) 77579 Summit Racing $1,139.00
VALVETRAIN
Comp Cams 294S Magnum cam and lifter kit CL-12-222-4 Summit Racing $195.95
Comp Cams Pro Magnum 1.52:1 roller rockers 1301-16 Summit Racing $265.69
Comp Cams Magnum double-roller timing set 2100 Summit Racing $32.95
Comp Cams dual valvesprings 925-16 Summit Racing $122.39
Comp Cams valvespring retainers 741-16 Summit Racing $59.99
Comp Cams valve locks 611-16 Summit Racing $24.88
Comp Cams valvespring locators 4771-16 Summit Racing $39.88
Comp Cams 51/416x7.900 Magnum pushrods 7693-16 Summit Racing $105.95
Comp Cams flat guideplates for 51/416 pushrods 4808-8 Summit Racing $21.88
Comp Cams 31/48x71/416 High Energy rocker studs 4500-16 Summit Racing $26.99
INDUCTION & FUEL
Edelbrock Street Tunnel Ram intake, complete 7110 Summit Racing $259.95
Edelbrock Performer 500-cfm carb (2 required) 1404 Summit Racing $449.76
Edelbrock throttle linkage kit 7097 Summit Racing $26.95
Edelbrock calibration kit (2 required) 1486 Summit Racing $47.88
OILING
Milodon oil pan, LH dipstick 30900 Summit Racing $139.88
Milodon oil pickup 18314 Summit Racing $34.88
Speed-Pro high-volume oil pump 224-4143 Summit Racing $26.95
Speed-Pro heavy-duty pump shaft 224-6146E Summit Racing $10.99
Silver Seal dipstick and tube TW6505CP Dougan's $7.00
Used stock bypass valve N/A Wrecking yard $10.00
Mr. Gasket spin-on oil-filter adapter 1270 Summit Racing $9.75
GASKETS
Fel-Pro head gasket (2 required) 1010 Summit Racing $73.90
Fel-Pro intake set 1206 Summit Racing $14.88
Fel-Pro RACE set 2702 Summit Racing $18.95
Fel-Pro one-piece oil-pan gasket, LH dipstick 1880 Dougan's $36.00
Fel-Pro Cork-Lam valve-cover set 1604 Summit Racing $27.95
HARDWARE
ARP main studs, small-journal, no windage tray 134-5402 Summit Racing $39.75
ARP head bolts, with stainless steel outer row 134-3603 Summit Racing $96.99
ARP Wave-Loc 11¼32-inch rod bolts 134-6401 Summit Racing $59.88
ARP oil pump mounting stud 230-7004 Summit Racing $6.50
ARP timing-cover bolts 200-1501 Summit Racing $9.95
ARP intake bolts 134-2001 Summit Racing $12.88
ARP valve-cover studs 400-7603 Summit Racing $18.88
Pioneer harmonic-damper bolt 859012 Dougan's $6.00
Pioneer oil-pan bolts 854001 Dougan's $15.00
Moroso distributor holddown clamp 26200 Summit Racing $7.95
IGNITION
Performance Distributors distributor & coil 14720 Performance Dist. $295.00
Performance Distributors Live Wires C9053 Performance Dist. $95.00
DYNO CONSUMABLES
Fram Autolite racing spark plugs (8 required) AR3933 Summit Racing $37.52
Lucas 10W30 synthetic engine oil (7 quarts) 10050 Summit Racing $48.65
ACDelco oil filter PF1218 Rock Auto $4.83
ACCESSORIES
Edelbrock Elite tall aluminum valve covers 4249 Summit Racing $71.95
Pioneer freeze plugs PE100BR Summit Racing $10.99
OEM Paints Chevrolet Orange/Red engine paint OE62020 The Paddock $26.95
Pioneer fuel pump block-off 839033 Dougan's $6.00
Used stock timing cover N/A Dougan's (Free)
Silver Seal timing tab 6544R Dougan's $5.00
MACHINE WORK & OTHER LABOR
283 crank: magnetic-particle-inspect, grind
0.010/0.010, heat-treat N/A Castillo's $327.00
Clean and inspect parts, deburr block, install freeze plugs and cam bearings, machine block, fit pistons and pins, resize rods, balance assembly, surface heads, valve job, assemble engine.
N/A Dougan's $2,667.00
TOTAL $8,467.72
*All prices are as of press-time and are subject to change.
PROVEN POWER
RPM LB-FT HP RPM LB-FT HP
3,000 305 174 5,100 354 343
3,100 302 178 5,200 352 349
3,200 301 183 5,300 351 354
3,300 301 189 5,400 351 361
3,400 302 195 5,500 350 367
3,500 306 204 5,600 351 375
3,600 311 213 5,700 350 380
3,700 315 222 5,800 347 383
3,800 318 230 5,900 343 385
3,900 321 238 6,000 339 387
4,000 325 247 6,100 335 390
4,100 328 256 6,200 334 395
4,200 333 266 6,300 332 398
4,300 336 275 6,400 328 400
4,400 340 285 6,500 326 403
4,500 344 295 6,600 322 405
4,600 348 305 6,700 320 408
4,700 351 314 6,800 316 409
4,800 352 322 6,900 310 407
4,900 352 328 7,000 302 403
5,000 353 336 HRM
techarticles/engine/0511_hrdp_chevy_302_based_engine
The Old Reliable:
Old Reliable
(Delmar Win, 6-02) This photo was taken in Victory Lane after "winning" the NHRA Delmar, DE US 13 points race, June 2002.
From left to right, engine builder, Bub Whitiker, Jerry MacNeish, Tim Bishop, and Mark Dickerson.
Old Reliable
Jerry MacNeish and the legendary Bill "Grumpy" Jenkins at the 1994 NHRA Keystone Nationals, Maple Grove, PA.
TECHNICAL DATA
VIN number 124378N411100
Build Date 04A (first week of April)
Color Corvette Bronze
Interior Code 712, black standard
Car Shipper Shipped on April 11, 1968 to Ammon R. Smith Auto Company, York, PA
Engine Data Cubic Inches, 302
Cylinder heads #3917291, completely stock, no porting allowed!
Stock rocker arms & valve springs
Intake 302 aluminum intake, casting #3917610
Carburetor Holley, #4053, 780 CFM 4bbl
Camshaft Crane, .480 inches lift, 272 degrees duration, valve lash, .016-.016
Pistons GM 302, .030" oversize
Horsepower 456 @7700rpm
Rear Tires 9" x 30.0" Hoosier's
Rear axle & ratio 12-bolt, 5.57 Richmond Pro Gears
Clutch 10 inch, three finger from Advance Clutch Technology
Shift Points 8200 RPM
BEST ET 10.80 @122.30mph
Jerry MacNeish E-Mail:
Z28CAMAROMAN@JUNO.COM 410-781-0418
