283 Oil Filler Tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2003, 10:04 AM
84 Z28 Convertible
283 Oil Filler Tube
Whats the best solution for the Oil filler tube hole in the front of older engines intake 283/327. I'm installing a Edelbrock rpm maniford, shall I Plug it with a Freeze plug or just cover it with the intake? If I dont cover it will it lead to blowby?
Old 11-09-2003, 11:00 AM
NorthStar's Avatar
I think that oil filler tube actually is pressed into the intake so you can just swap your new intake on. If your intake already has a hole for oil fill tube just plug it with a 1 1/2" cup plug.
But now youll have to find some newer valve covers with an oil fill.
Old 11-09-2003, 02:15 PM
Tazz
The correct solution
Use the correct intake allowing for the oil fill tube. I have never heard of any way around the tube hole?? Isn't it also the crankcase vent??
Todd
Rat Rods Rule!
Old 11-09-2003, 02:21 PM
poncho62's Avatar
Wiki Edits: 5
It is a crankcase vent, but the valve covers were not vented. Put later covers on with a filler, vent and PCV valve and you are all set.
If you put a PCV valve on, you can also plug the blowby tube (pre 65)
Old 11-09-2003, 02:56 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
There is a sealed pipe that was used on the 302 DZ engines. I've plugged many manifolds with freeze plugs and they work just fine.
Troy
Old 11-09-2003, 05:57 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
I use mine as a extra breather.
Luv the smell of NITRO in the morning.
