283 oil leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2010, 11:52 PM
283 oil leak
Hello, I am familiar with the newer small block chevy engines but I have never really worked on an older block. I just bought this car with a 64-68 283 and it is leaking lots of oil out of a breather on the back of the block right by the oil sending unit and distributor. Any suggestions for me? Thanks!
Old 06-21-2010, 12:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That tube was there to vent the crankcase- aka "road draft tube".
You may find that the engine has a lot of blow-by causing the "leak", unless the oil level is too high.
There are ways to convert the draft tube to a PCV valve system, but I'd want to get to the bottom of why there's so much oil coming from the tube.
You could start with a vacuum gage, and a compression check or leakdown test to determine the condition of the ring and valve seal.
Old 06-21-2010, 01:36 AM
Yeah I wouldn't be surprised if there's a lot of blow-by (rings), especially if the engine is original. I used to plug that hole and run valve covers with breathers. I'll put my money on that engine still being original. I don't know anyone that would put that set-up back on, after a rebuild (except for someone doing a "correct" restoration).
Old 06-21-2010, 03:16 AM
techinspector1's Avatar
Wiki Edits: 326
Time to roll out the toolbox.
Old 06-21-2010, 06:51 PM
Ok thanks, so for a while I should be able to get away with plugging it and running breathers on the valve covers? I dont want to do anything major to it this summer.
Old 06-22-2010, 07:54 AM
T-bucket23's Avatar
Wiki Edits: 26
You will most likely need a PCV setup. If it is blowing oil out the tube, it will probably blow it out the breathers as well if you don't have a PCV.
As mentioned above, you most likely have bigger issues. Oil from the breathers or vent tube usually means a tired engine with lots of blow-by
Chet
Old 06-22-2010, 09:34 AM
I did some more thinking and I might just put a bone stock 350 vortec in it for a quick swap. By the way it is in an old triumph tr6 so it does not need a whole lot of motor to get it going decent.
Oil Leak NickO Engine 5 07-02-2007 08:18 AM
clues needed for 460 oil leak cboy Engine 2 07-21-2006 03:32 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 07:07 PM
oil leak 4.8l ford Walker Engine 4 11-06-2003 09:30 PM
